Help! Can't mount my microphone on the Z1U at DVinfo.net
Old April 7th, 2005, 04:31 PM   #1
I just got an Audio Technika AT835ST microphone for my Z1U.
BUT it won't fit the hole! Its too narrow for the hole! It wiggles!
So what now? I don't really want to mount it on the shoe, since I will be using that for a light.
So please help!
Anyone here using this microphone on a Z1U?
Thanks in advance.
Hse Kha is offline   Reply With Quote
Old April 7th, 2005, 05:17 PM   #2
I had the same problem but it can be solved by wrapping some foam around the mic inside the holder.
Simon
Simon Harris is offline   Reply With Quote
Old April 7th, 2005, 08:24 PM   #3
I cut a strip of foarm and wrapped around also. Works fine. (AT897)
Jerry Waters
Arize Productions
Jerry Waters is offline   Reply With Quote
Old April 8th, 2005, 07:28 AM   #4
Thanks guys, I guess I will have to test my DIY skills...
But isn't there some pre-made adapter out there?
Old April 8th, 2005, 08:22 AM   #5
Someone does - for $330.
http://www.creativevideo.co.uk/gimme/storereframe.php?session=313715476&view=item&item=cvp-bracket-z1e
Foam is cheaper
Jerry Waters
Arize Productions
Old April 10th, 2005, 08:59 AM   #6
Hi!
had the same problem with the $500 Sennheiser B&H sold me with the Z1. When I asked if they sold a product that helped pad the mic., they said no, use electrical tape. Oh well...
Cheers!
Andrew Stone
A. Stone is offline   Reply With Quote
Old April 10th, 2005, 11:01 PM   #7
Get a piece of bicycle inner tube....works like a charm.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old April 11th, 2005, 08:08 AM   #8
Good advice ... I knew I should have kept those tubes around for something!
Andrew Stone
Old April 12th, 2005, 12:59 PM   #9
I've temporarily been using elastic bands wrapped around the barrel of the A-T. A piece of inner tube would look much more elegant.
Thanks for the tip.
Mark Woollard
Mark Woollard is offline   Reply With Quote
Old April 12th, 2005, 04:48 PM   #10
Maybe we should buy one and cut it up at NAB (and if Spot doesn't share all the new secret stuff we could shoot him with the bands).
Jerry Waters
Arize Productions
