Two heads are better than one...what's a good second monitor? at DVinfo.net
Old April 11th, 2005, 06:23 PM   #1
Well it's clear that if I'm going to edit effciently, I'll need a second monitor. I currently have a 21" CRT, which is great, but it'd be nice to move the timeline and other tools to a second monitor. Any suggestions?
Camera: Z1
NLE system: PPro 1.5.1
Nvidia GeForce6800GT video card with two monitor output (analog and digital out)
Andrew Stone
A. Stone is offline   Reply With Quote
Old April 11th, 2005, 09:28 PM   #2
I recommend matching LCDs or if you have the room, matching CRTs. Don't have two different monitors.
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline   Reply With Quote
Old April 11th, 2005, 10:00 PM   #3
It's not a big deal to have mismatching monitors as long as you know their primary uses will be different. If you have a good CRT and a good LCD, put the timeline on the LCD, as the CRT will have better dynamic range and greater contrast consistency over the range of viewing angles.
I haven't bought a monitor in a while, but that may be because I bought the right ones the first time: ViewSonics.
If you'll only be using your new monitor for timelines and controls, go with whatever old cheap monitor your retailer has on special. Fairly good new monitors go for between $150-$300.
All the best,
Robert K S
Search DVinfo.net for quick answers | The best in the business: DVinfo.net sponsors
Robert Knecht Schmidt is offline   Reply With Quote
Old April 12th, 2005, 11:49 AM   #4
Once again...many thanks for the advice!
