Z1 LANC zoom disappointment
Now that my workload has eased a bit I've had the time to do a zoom speed test on my different cameras. I just finished shooting 4 performances with my Z1 and am generally very pleased, but my gut reaction was that the zoom speed was very fast as compared to my PDX-10 when using the same LANC controller. Well it turns out this is true unfortunately. I have a Varizoom Pro-L controller and use it with the speed dial set to the minimum:
http://www.varizoom.com/products/controls/vzprol.html The slowest zoom from full wide to full telephoto was 22 seconds on the Z1, more than twice as fast as the 45 seconds the PDX-10 takes using the same controller at the same setting. HOWEVER, using the Z1's rocker zoom lever I was able to get a 75 second zoom (see also this thread where John and Shawn were able to get a 105 sec zoom with the built-in rocker - it's very difficult to maintain that speed and they obviously practiced more than me :-) I also tried the same test on my VX-2000 and interestingly the Varizoom took 22 seconds there too, as did the camera's rocker zoom. So what's up with the Z1? Is there some other type of lens control that can achieve a slow, steady zoom? Are they not properly implementing LANC, or is the slow rocker zoom some sort of internal function which can't be remote controlled? This is a disappointment for event work where you're on a tripod and want subtle zooms without touching the camera and causing it to shake. |
Boyd,
I've noticed this on both the FX1 and the Z1, when using my Manfrotto 523Pro LANC controller. Like you, I'm still better of using the zoom rocker for really slow speeds. There must be something amiss with the LANC settings surely - I mean since slow zooms can be achieved... Robin |
Robin
Since you have both FX1 and Z1 is there any difference in the ramp to start/stop the zoom. I am disappointed in my FX1 as it starts and stops very abruptly compared to my TRV50 or PC10 or even the TRV740. There is a smooth zoom feature on the Z1 what is this? My controllers are manfrotto 521 and two Sony Lanc controllers. With all these controllers the zoom on the TRV50 is very controllable and proffessional looking but no matter what I do with the FZ1 it has abrupt stop and start very amateur looking I have tended to pan just a little before starting and stopping to mask the effect. IT may be that the Lanc controllers are not starting on the slowest speed which may be the only one with a ramp on the motor control though I am unable to smoothly start or stop with the rocker!!! Ron Evans |
I don't really have any complaints about the start/stop on the Z1, it seems smoother than my PDX-10. Although the faster speed tends to make any stop or start a little more abrupt. But the PDX-10 has a very annoying glitch (which others have also noticed) where the image goes a bit out of focus at the end of a zoom to max telephoto until you release the lanc control.
#5 | |
The secret to the 100 sec figure is to slightly reduce rocker pressure after starting the zoom and it slows down. Its as if the rocker needs a threshold pressure to begin the zoom then it can be backed off a little for the super slow 0.5 mm/sec rate. Of course you have to practice, but thats half the fun - try a super slow reveal out of a CU at 1/3 composition whilst maintaining headroom - which involves micro pan and micro tilt movements - then you will know you have arrived ! Of course all of this is moot if your cam is ten feet in the air at the end of a jib :( I suspect the Z1/FX1 uses a look up table which is different from its other range so a Lanc command of slowest is interpreted as 4 x times the slowest in the table - bad news for 3rd party controllers I am looking into having a handle mounted cable release assembly made which will operate the A & B shot transx buttons as well as applying just the correct pressure for super slow zoom - thats three cables total, each of which will be quite long for jib work.
John Jay Beware ***PLUGGER-BYTES*** |
#6 | |
The shot transition would seem like a handy way to get around these issues but unfortunately it's limited to the handle zoom speeds which also max out at 22 secs. Sounds like a cool gadget you're working on, I read about that in another thread. Let us know how it turns out! |
#7 |
Sponsor: VariZoom
Z1 zoom speed
Boyd,
You are correct about not being able to achieve the slowest speed with your controller. The slowest speeds I have seen reported so far with a VariZoom and Bogen control have been 24 seconds. If Sony has a way to access that slower speed they have been unwilling to share it. It may be impossible to activate this slow speed by remote. It is unfortunate and frustrating because it would be so nice to utilize those slow speeds by remote. I have both the Z1 and FX1 If it becomes possible to implement these speeds by remote we will make it available immediately. Being in the control business we get many calls from videographers when considering a purchase of a new camera. I know it has cost many sales for Sony. Tom VariZoom Lens Controls |
#8 |
Oh well, as I suspected. But there are a LOT of other things to like about these cameras.
Mark me down for an order if you ever figure out how to make a controller that accesses the slower speed! :-) |
#9 |
Sponsor: VariZoom
Zi Zoom speeds
Boyd,
I just forwarded Sony your post, along with a few others, and hopefully they will consider addressing the problem. Tom McKay www.varizoom.com |
#10 |
Hi Thomas you can forward my posts too. It is really dissappointing to have such a great camcorder that can't match the lower priced consumer camcorders ( though come to think about it the PC10 wasn't much less when I bought it!!!!)for zoom performance with Sony's own Lanc controllers. With both Sony controllers that I have and the Manfrotto 521 I can make the PC10 and TRV50 very smooth start and stop that is impossible with the FX1. Even the rocker on the FX1 doesn't have the ramp start and stop that appears to be on the PC10 and TRV50. The reason that I asked about the Z1 is that it is the sort of thing Sony does between the prosumer and Pro products, fundamentally the same product just different firmware for features.
Ron Evans |
#11 |
Thomas,
are you using ?: 00H variable speed zoom Tele: slowest speed 10H variable speed zoom Wide: slowest speed if so have you tried ?: 35H Zoom Tele slow 37H Zoom Wide slow where the hex bytes are from Sub-Command in Byte 0
#12 |
Just to add, Bebob Zoe DVL on its slowest setting gives 22 secs. :-(
A real pain that to get the 70+ second zoom, the big rocker is the only way. This is useless for our applications, especially as you can't guarantee pressing the rocker lightly, yet continually, yet not stopping mid-zoom.
Martin at HeadSpin HD on Blu-ray |
#13 |
<sigh> and you got my hopes up with that other post about the BeBob ;-)
I wish Sony would fix this... maybe it would only take a firmware patch? It's ridiculous that the slowest LANC zoom speed on my Z1 is twice as fast as my little PDX-10.... |
#14 |
Did anybody ever find a way of getting a slow zoom via LANC?
(In fact, I find I can get c.80 seconds to zoom in, and c.130(!) seconds to zoom out but only with the big rocker on the body, it's just that is frustratingly unreliable to use, just when you want a controllable zoom. Sigh too.)
#15 |
You guys have widened my eyes, and my Z1's the same: 22 seconds using the slowest Zoe setting, and 72 seconds on the big rocker. Quite a surprise.
tom. |
