can you copy scenes from TV to your Z1? at DVinfo.net
Old January 4th, 2006, 07:40 PM   #1
The manual says you can but after following the instructions I continue to fail to do it. Anything i should do that the manual is not describing? Has anyone recorded TV images through VCR or directly from tv to the Z1?
Maximo
Maximo Salaberry is offline   Reply With Quote
Old January 4th, 2006, 07:42 PM   #2
I haven't tried, but I believe this is only possible when the camera is set for DV instead of HDV mode. Could that be your problem? What happens when you try? How are you connecting the TV to your Z1?
Old January 4th, 2006, 07:52 PM   #3
With your camera on VCR mode, go to the IN/OUT REC section of your camera's menu and turn A/V->DV OUT on. I think that's how I got it to work when I was recording to my camera about a month ago.
Are you using an RCA or s-video input? I remember it working for me with RCA.
Mark Utley
Mark Utley is offline   Reply With Quote
Old January 4th, 2006, 11:23 PM   #4
Perfect!
You guys are fantastic. It works, i think i forgot to change it to DVCAM/DV instead of HDV.
THank thank you thank you.
maximo
