Converting 1080i to 720p -- does it look good? at DVinfo.net
Old August 8th, 2006, 05:14 PM   #1
I have a JVC HD100 (720p) and I would like to supplement it with a handheld camcorder like the FX1. My question is: if I use something like MPEG Streamclip to change the 1080i footage of the FX1 to 720p, will it look like "native" 720p? In other words, will it match the 720p of the HD100?
Bill Edmunds is offline   Reply With Quote
Old August 9th, 2006, 03:04 PM   #2
You will want to deinterlace first then scale it down. It should look good, but how close to the other camera will depend on how you set it up in the first place.
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline   Reply With Quote
Old August 9th, 2006, 06:05 PM   #3
If your going to 30p it should look perfect with just a quick deinterlace, drop it in your timeline, render and your set. 24p will be a little bit more tricky.
Mack Fisher is offline   Reply
