Why is the time code not counting when I record? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old January 8th, 2009, 04:35 PM   #1
Hi,
While I record on my new Z5U the time code says 00:00:00:00 the whole time. Why is it not counting?
Marco Giordani is offline   Reply With Quote
Old January 8th, 2009, 07:00 PM   #2
Are you sure you're seeing the colons? You're sure it's not reading 00 00 00 00 instead of 00:00:00:00?
Page 89-90 of your manual.
Old January 9th, 2009, 05:28 AM   #3
Thanks Adam I found out the issue.
Their is a button under the LCD monitor called TC/U-Bit. I must of had it on U-Bit, (whatever that is?)
Thanks.
Old January 9th, 2009, 07:57 AM   #4
U-Bit is to let you manually add info to the tape for whatever purpose you like. You could come up with a naming scheme that let's you know what you tape you have. Check this thread out:
User bits - what is it? - The Digital Video Information Network
http://www.nosmallroles.com
Vito DeFilippo is offline   Reply With Quote
Old January 9th, 2009, 08:03 AM   #5
Cool Thanks Vito!
Old January 9th, 2009, 01:27 PM   #6
Yeah, that's why I asked about the colons. With colons, you are seeing TC. Without, U-Bits.
Old January 9th, 2009, 03:28 PM   #7
Ahhh got it.
Thanks Adam.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
