CF change out time at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old February 27th, 2009, 05:36 PM   #1
CF change out time
How long does it take to start recording again when changing out a CF card? That is, stop recording, remove card, insert new card and begin recording again.
Bill Rankin
Bill Rankin is offline   Reply With Quote
Old February 27th, 2009, 06:47 PM   #2
Bill, a bit of that is determined by the speed of your card as I've found out. I have 2 cards, one is a 133X and the other a 300X card. The 133X takes about the same time it would take to change out a tape...perhaps a bit longer as the card mounts and is read. The 300X card is closer to the actual time to change out a tape. Either way, it's no more than about 25 seconds.
Ken Ross is offline   Reply With Quote
Old February 27th, 2009, 07:10 PM   #3
Thanks, Ken...I was hoping for a more instantaneous startup.
Bill Rankin
Old February 27th, 2009, 07:28 PM   #4
Not only does it take a little while for the MRC1 to recognized the new card, you can't instantly remove the old card as soon as you press stop. It takes a little time taken for the CF card to finish recording the buffered information. It doesn't stop recording the instant you press stop.
Another related question. I haven't really read the Sony manual in detail but I know my Nikon D200 manual says you should turn the power off on your camera before removing a CF card. Does Sony say anything about powering down the MRC1 before swapping cards?
Greg Laves is offline   Reply With Quote
Old February 27th, 2009, 09:48 PM   #5
Greg, I think that's just good practice with any recording media...power down first before removing the media.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
