Battery charger at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old March 3rd, 2009, 09:03 AM   #1
Battery charger
What kind of charger are you guys using. I find the AC-V700A (AC-V700A (ACV700A) : Zubehör & Kopfhörer : Sony) a bit pricy for charger ...
Thanks for any hint
Regards
Peter
Peter Schmiedel is offline   Reply With Quote
Old March 3rd, 2009, 10:26 AM   #2
My Z5 came with this charger:
Sony : AC-VQ1050B (ACVQ1050B) : Technical Specifications : United Kingdom
so there is no need to buy any other one.
Stelios
My Blog: http://steliosc.blogspot.com
"I hope for nothing, I fear nothing, I am free" Nikos Kazantzakis
Stelios Christofides is offline   Reply With Quote
Old March 3rd, 2009, 01:52 PM   #3
Stelios
And, of course, has the added advantage of being an AC adapter for the camera.
Steve Renouf is offline   Reply With Quote
Old March 3rd, 2009, 02:13 PM   #4
The only disadvantage I can see Steve, is that when you are using the AC-VQ1050 AC adapter to power the Z5 you need to remove the battery from the Z5 and use the mock-up battery unit connected to the AC adapter, so when there is a power failure you are in trouble.
Stelios
Old March 4th, 2009, 09:24 AM   #5
Stelios
Good point Stelios. Although the same would apply if the battery went flat, requiring a battery change - although you do have somewhat more control over that. I only really tend to use the AC supply when capturing - at which point it wouldn't make any difference if the power supply failed, as the PC would also lose power in any case.
Old March 5th, 2009, 12:53 AM   #6
I was more refering to the FX1000 as it does not come with a separate charger and I really don't liek to use the camera as a charger ...
Old March 5th, 2009, 02:38 AM   #7
From "earlier times" I still own a Sony BC-V615, which I bought for my VX2000E. Maybe these can be found used on the net for a lower price.
Jo Ouwejan is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
