Fx1000: display in feet not meters at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old April 14th, 2009, 09:31 AM   #1
When adjusting focus manually, the distance is displayed in metres (meters). How can I toggle this to feet?
Barron Thompson is offline   Reply With Quote
Old April 14th, 2009, 01:43 PM   #2
I know there is a menu setting on the Z5 to toggle it between feet and meters, and it's found in:
Display set -> Focus Display
Check to see whether the FX1000 has the same option. I had a quick scan of the FX1000 manual, and I believe it does not have this option, unfortunately.
Ben Hall is offline   Reply With Quote
Old April 14th, 2009, 02:34 PM   #3
The FX1000 does not have that menu item. I too checked the manual before starting the thread and was hoping for a trick key press or something else to get the units changed.
Old April 14th, 2009, 05:35 PM   #4
I would have assumed that the FX1000E is in Meter and the FX1000 in feet ... sure you did not get the European version ?
Peter Schmiedel is offline   Reply With Quote
Old April 14th, 2009, 07:10 PM   #5
Fairly certain. Purchased it in Toronto, Ontario, Canada and not online. We are metric here and have been for decades.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
