Please reinsert the tape at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old December 5th, 2009, 12:16 AM   #1
This keeps coming up when I try to load up a take
so I put in another tape and it worked then I went back to the tape that was giving me the error and it was working fine.
So I was able to get my footage off of the tape.
I was wondering if any of you had this problem and could it be the take?
I am using Fujifilm tape but I don't think they are really all that good. I just needed something last minute and thats all that was at the store
Luie Dalmasy Jr. is offline   Reply With Quote
Old December 5th, 2009, 01:25 AM   #2
If you switched brands without cleaning in between, it's possible the new tape uses a different lubricant than your prior one and it may have gummed up the heads a bit. Standard advice is to stick to one kind of tape if possible and if you do switch, clean before and after.
Old December 5th, 2009, 02:23 PM   #3
Looks like an intermittent problem. Try cleaning the contact, the four holes beside the switch at the back of the tape.
Sony Z7U, Canon 5D Mark II, Canon 24-105 F4L, Canon 70-200 F2.8L, Canon 580 EXII, Zoom H2.
Jun Galinato is offline   Reply With Quote
Old December 7th, 2009, 06:32 AM   #4
Tape lubricant would have nothing to do with the error the OP was seeing. Lubricant issues simply clogs the heads. I have seen this once or twice with my VX-2100. It is quite alarming when it happens. Like you, I later tried the same tape and it was fine.
Does anyone know exactly what has to happen within the tape mechanics to generate this error?
John Gayman is offline   Reply With Quote
Old December 7th, 2009, 06:35 AM   #5
Aren't those contacts only used if you have the Sony tapes with the memory chip inside? I tried one of those when I first bought my VX-2000 and didn't see any advantage to them (and the extra cost) so I stuck with standard non-chip tapes. On all my Sony DV tape those four holes are filled with plastic as opposed to gold contacts.
Old December 7th, 2009, 02:34 PM   #6
Maybe yes, maybe no. Seems to me it could affect the entire tape path, but you may be right.
Old December 7th, 2009, 08:25 PM   #7
I have a PD170 before acting like that. Looks like an intermittent tape mechanism, posible motor getting weak, or rubber belt getting loose, who knows.
Jun
Old December 9th, 2009, 09:47 PM   #8
I've had some tape messages on my VX2000 when in humid environments, and I've had what must have been a bad tape once that kept giving me an error. I finally put in a new tape and message never came back.
Mark Goodsell
Mark Goodsell is offline   Reply With Quote
Old December 13th, 2009, 12:37 AM   #9
had it a couple of times with my 170, but used to get something similar with my 300sp rig - usually a slack wound tape (ampex always seemed to cause this).
Leslie Wand is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
