thin uv filter? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old January 16th, 2010, 06:13 AM   #1
thin uv filter?
any suggestions for a thin 72mm uv filter that will allow a second screw on filter (cpl / cc / etc.,) if necessary?
Leslie Wand is offline   Reply With Quote
Old January 16th, 2010, 05:47 PM   #2
I bought this filter recently for my Z5 (same seller, actually). Brand new, great quality, and it is very low profile. Will accept additional filters. I thought it was a good buy for a quality filter compared to the price of other filters on Ebay and definitely cheaper than B&H. Also bought a Vivitar Circular Polarizer (CPL) filter from the same outfit and if I remember they combined shipping. Like I said, I thought the quality was great on both items and have had no problems. I generally don't stack filters. I'll pull the UV filter off when I put on the CPL. I try to limit the extra glass in front of a great Sony lens. That's just me. I also have a Moose's filter that we have had for several years for use on a DSLR. A Moose's filter is a combination of a CPL and warming filter. Great for landscape and outdoor work. I use it on the Z5. You find someone selling them cheap on Ebay from time-to-time. Good luck.
VIVITAR UV 72MM FILTER Multi-Coated SR 1 FOR HOYA HMC - eBay (item 270514367312 end time Feb-11-10 12:30:46 PST)
Mark Goodsell
Mark Goodsell is offline   Reply With Quote
Old January 17th, 2010, 03:18 AM   #3
thanks for that mark, appreciated.
i'm after one for a 'lens protector' really, but i have a matt box that i can use with a screw in 72mm adaptor - so i'm hoping there's enough thread left AFTER the uv to screw in the adaptor....
leslie
Old January 17th, 2010, 09:25 AM   #4
There should be enough thread left, but if it's a heavy matt box, you might want to look for a thicker filter as it might be a little more robust..
Mark Goodsell
Old January 17th, 2010, 08:12 PM   #5
thanks again mark....
will have to look into it....
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
