jagged edges at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old February 15th, 2010, 11:19 AM   #1
jagged edges
good morning,
Here is a frame. the boards, particularly the yeoow line is jagged.
is this fixable by canera technique, or in post.
is this the rolling shutter issue?
dale
DATS ALL FOLKS
Dale W. Guthormsen
Old February 15th, 2010, 08:29 PM   #2
were you panning as you took that shot? looks like rolling shutter effect.
Lukas Siewior is offline   Reply With Quote
Old February 15th, 2010, 10:36 PM   #3
YES i WAS SWINGING LEFT TO RIGHT.
dALE
DATS ALL FOLKS
Dale W. Guthormsen
Old February 16th, 2010, 02:54 AM   #4
They say you could avoid that, by shooting Progresive iso Interlaced.
Jo Ouwejan is offline   Reply With Quote
Old February 16th, 2010, 12:05 PM   #5
Panning/scanning is more problematic in progressive. Panning in progressive is relatively OK as long as you are following a subject.
Old February 16th, 2010, 05:09 PM   #6
Good evening,
In general the subjects on this hockey game were quite good even though lighting was dismal, typical of small community rinks. The problem laid with the background not being very pristine.
I shoot with depth of field max so that there are minimal focusing issues as the players go end to end; hence, less manual movement of the lens and keeping them relatively sharp.
In this regard the fx 1000 has been awesome, much better than my four canons.
Now this footage had to be down rezed to SD for delivery and it made the jaggies of the horizontal line more noticable!!!
Is there a way i can fix this or avoid it!!!
I was looking seriously at an ex 3 and did not buy one for fear of the rolling shutter in high movement shots, (90 % of what I do is high speed action.) I am now thinking that was perhaps a wise move.
PLease correct me if I am worng or there is a way to get around this!!! I think this is an awesome little camera!!!!
DATS ALL FOLKS
Dale W. Guthormsen
Old February 17th, 2010, 08:04 AM   #7
Dale, this is such a minor issue in your image I would just move on. Don't lose perspective...you are not shooting with broadcast cameras, nor should you expect your video to be broadcast quality with 1/3" sensors in the low-lit hockey rink. Just shoot the best you can and forget it. This is not rocket science, nor hollywood. I would suggest that you finish the project and move on to the next one. Obsession over these things we have virtually no control over is not healthy.
Old February 17th, 2010, 11:56 AM   #8
Jeff,
Thanks for good advice!! I do tend to obsess over small things.
Moving on. Until I win the lottery and start with a genisis.
Dale
DATS ALL FOLKS
Dale W. Guthormsen
Old February 18th, 2010, 02:08 AM   #9
as jeff rightly says - move on.
we all want perfection, but perfection comes at a high price usually. i doubt even a ex3, or any 'prosumer camera' would give really noticeably better results.
better send a circular to the rinks pointing out that their abysmal lighting is ruining your footage ;-)
and, if your audience is watching the jaggies, they obviously aren't interested in ice hockey ;-)
Leslie Wand is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
