Dropped audio frames/wrong audio at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old February 26th, 2010, 07:52 AM   #1
I am using the FX1000 with the MRC1. While recording dancing at the wedding, the last clip on the card the audio dropped out 3 times for about 40 frames (each time the duration was different & there was no dropped video frames). The last time it dropped frames the audio it recorded was from 5 minutes earlier on the same clip. Usually I also record to tape but there were only a couple of dances left so not tape backup. I tried to re-import the clip & no difference. Any ideas why this happened?
Thanks in advance for your help.
Allen
Allen Bartnick is offline   Reply With Quote
Old February 26th, 2010, 08:50 AM   #2
Did you use the Sony utility program or did you pull it directly off the card? If not, use the utility program. Although, that doesn't sound like a typical problem. Maybe it's a card issue. What cards are you using?
That's par for the course. Just when you think you can get by without tape Murphy steps in. I'm still paranoid when I go without tape. I know it's mostly in my head but I just can't get around it.
Rob Morse is offline   Reply With Quote
Old February 26th, 2010, 10:23 AM   #3
I first used the Sony utility than I also took it straight from the card. I use the Sandisk Extreme 3-32gb.
Old February 26th, 2010, 01:25 PM   #4
I have no idea and everyone raves about that card. I personally want a speed of at least 300x and that's why I waited when the Extreme 3's had that big rebate. It's probably irrelevant but that's what I have in my head. It could just be a one-time freak thing. Is the MRC-1 new? On 2 or 3 occasions I've had to go to the tape. One of the times it was a necessity. Not to beat a dead horse but that's why I went with the Z5 over the EX1. It's worth a little piece of mind.
I just realized you're using the FX1000, what about the cable from the camera to the MRC-1?
Old February 26th, 2010, 02:22 PM   #5
I'm using the firewire cable that came with the unit. It's fairly new, I've used it about 12 times with no other problems.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
