Full Time Code in FX1000 Flip Out Display at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old April 19th, 2010, 11:30 AM   #1
Can the FX1000 show the full time code, last two digits for frame rate and first digit for multi-hours?
Kevin O'Connor is offline   Reply With Quote
Old April 19th, 2010, 12:03 PM   #2
During recording, no to frames, yes to hours. During playback, yes to both. Page 128.
But remember that the FX1000 does REC RUN TC only, so unless you're using an extended length tape (or are recording in LP DV mode) your hours column will likely never go above zero during recording.
Old April 19th, 2010, 07:43 PM   #3
Darn, I thought that was the case.
Thanx,
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
