Z5 audio display with db at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old April 28th, 2010, 10:25 PM   #1
On my LCD when I record footage, I can only set audio level by "guessing" that -12db is just over halfway.
Is there a display setting that shows me the db markers - ie. -6, -12, -18, etc.otherwise it's a bit dodgy - don't you think ?
Chris Duczynski is offline   Reply With Quote
Old April 29th, 2010, 08:58 PM   #2
I haven't found a way to do this or any reference to it in the manual.
Old April 30th, 2010, 07:45 AM   #3
db display
Press the "status check" button. It's the control button closest to the battery compartment along the the bottom of the camera. The info will cover most of your LCD so it's really only good for setting peak levels rather than constant monitoring.
Rian Maelzer is offline   Reply With Quote
Old April 30th, 2010, 10:58 AM   #4
Wow, good catch.
Old May 2nd, 2010, 04:40 AM   #5
You're a legend Rian - thanks
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
