Reviewing clips at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old January 28th, 2008, 05:01 PM   #1
Reviewing clips
I don't have any experience in solid state camcorders but was wondering if you're recording to tape and to the flash card will you be able to review a clip from the flash card (without rewinding the tape)?
Kevin Crockett is offline   Reply With Quote
Old January 29th, 2008, 11:04 AM   #2
Good question, I wonder about that too.
Adam Folickman is offline   Reply With Quote
Old January 29th, 2008, 11:54 PM   #3
Yes,
The CF unit has a firewire port to connect to an HDV gear.
The HDV gear accepts the HDV stream then outputs video signal.
You don't need cabling in case of Z7U and S270U.
FYI:
http://www.advance-pro.com/downloads...270_z7_m35.pdf
Kenny Pai is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
