With the Z7U a couple of us are having this trouble with the CF cards - Page 2 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old April 5th, 2008, 04:46 PM   #16
Originally Posted by Marshall Levy View Post
Also, your statement of 133x = 160Mbs....where'd you get that from? The equivalent is 20-25 whereas 266 yields 40~ and 300/306 yields 60~.
The definition is quoted on the Sandisk site amongst other places, but from Wikipedia - http://en.wikipedia.org/wiki/CompactFlash - look down to the last paragraph of the section "Technical Details":
"Card speed is usually specified in times ratings, i.e. 8x, 20x, 133x..., ...... where the number in front of 'x' when multiplied by 150 kB/s gives the speed of the card (for example, 20x = 3.0 MB/s)."
Note that 1x is 150 KBYTESs, so 1200Kbs. Hence it follows that 133x is 133x0.15=19.95MBs or 133x1.2=159.6Mbs, close enough to 20MBs or 160Mbs.
Going a bit off topic, but I like another quote from that Wikipedia entry: "CompactFlash cards are capable of withstanding more physical damage in comparison to other, flimsier designs. Recently a CompactFlash card was found to be still working after spending two years inside a camera that was submerged in shallow water"
Old April 20th, 2008, 12:59 PM   #17
I just noticed this on Newegg.com :
http://www.newegg.com/Product/Produc...82E16820183191
Its out of stock, but I might pick one up to play with it. When/if I get it, I'll post a review.
-Chad
Chad Dyle is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
