Z7 with a Nikkor 70-300mm fitted at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old May 24th, 2008, 05:47 AM   #1
Here is a pic of my Z7 with a nikkor 70-300mm lens fitted via the Mike Tapa mount:
The Moon shot here: http://www.vimeo.com/1034579 Was done with this set-up
Old May 24th, 2008, 06:43 AM   #2
With that setup, is your only control of the camera transport through the lanc controller?
Laurence Kingston is offline   Reply With Quote
Old May 24th, 2008, 08:02 AM   #3
Yes but just for start stop of recording all zoom, apperture and focusing is done manual.
Old May 24th, 2008, 02:29 PM   #4
There is always a REC button on the top of the handle. I wish Sony had added one more REC button on the side. The one on the top becomes hard to reach when the camera is mounted upside down.
Tim Dashwood
Old May 24th, 2008, 03:46 PM   #5
Doh! of course I forgot to mention that the top of the camera has a rec switch as the lens one has been removed.
Old May 24th, 2008, 09:33 PM   #6
great shot
Kevin Li is offline   Reply With Quote
Old May 25th, 2008, 12:42 PM   #7
Woah....
are u saying u dont need an expensive and bulky adapter like letus or red rock?? just fit the 35mm lens onto the tapa?
where and how much for the Tapa adapter??
Sherif Choudhry is offline   Reply With Quote
Old May 25th, 2008, 06:21 PM   #8
Yes just put the tapa mount on and fit your Nikkor lens.
Around £220 inc vat and delivery and I got mine from e-bay:
http://myworld.ebay.co.uk/mtf_lenses
Old May 26th, 2008, 07:15 PM   #9
the big difference for the Red, Letus, etc. etc. is that those use 35mm lenses & keep the FOV (field of view) the same as 35mm. the stock lens on the Z7/S270 is a 4.4mm to 52.8mm.
on 1/3" chips (ie Z1/Z7/S270 plus many many more cameras), 52.8mm is a telephoto lens (read FOV). 50mm on a "35mm chip" (35mm negative) is a normal lens (FOV).
more or less you'll be 7x more zoomed in on your subject if you put a 100mm lens on the MTF (Tapa) adapter than if you put that same lens onto the Red/Letus
ALSO check out http://www.mtfservices.com/ for the home page of the Tapa adapter
Zach Love is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
