Microphone Rumbling (Excess Bass?) at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old August 18th, 2008, 07:30 PM   #1
Hi all,
Has anyone noticed quite a heavy bass rumbling with the supplied mic?
I've got things set on AUTO gain, NR on, Wind OFF, and notice quite a bit of bass noise. I need to add a highpass filter in post to eliminate the rumble effect.
How is your audio? What settings are you all using?
John Knight is offline   Reply With Quote
Old August 19th, 2008, 03:15 AM   #2
I have NR on and wind on for use outside and also have a windcutter fitted:
Old August 19th, 2008, 06:59 AM   #3
Originally Posted by John Knight View Post
Hi all,
Keep auto gain off and add the hi-pass filter in post. NR off; wind on (it is just a hi-pass filter which is better done in post)
kdbf
Keith Forman is offline   Reply With Quote
Old August 20th, 2008, 02:22 AM   #4
I found that when listening on cans with the NR off I could hear all sorts of RF and whirring sounds from the tape mechanism.
Gary Nattrass is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
