Rectilinear Wide Lens?... at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old September 17th, 2008, 12:17 AM   #1
Does anyone know if the optional wide lens Sony sells for the Z7U is rectilinear?
In other words...no barrel distortion or the "fisheye" look.
And is it on sale yet?
Anyone have it?
Wanna post video if you do?
Thanks.
-BillP
Bill Petropoulos is offline   Reply With Quote
Old September 17th, 2008, 04:08 PM   #2
Not sure about the Sony one. But this Century Optics one is now shipping and would love to hear about it first hand....
Century Precision Optics | 0HD-06WA-Z7U 0.6x Wide | 0HD-06WA-Z7U
Over 28 years watching TV
John Knight is offline   Reply With Quote
Old September 17th, 2008, 05:32 PM   #3
I'm sure that adapter will have plenty of barrel distortion. No good for me.
-BillP
Old September 17th, 2008, 06:43 PM   #4
Check the SAMPLE tab - looks ok to me...
.6X WIDEANGLE HD Z7U/S270U BAY - Schneider Optics
Old September 17th, 2008, 07:58 PM   #5
The Sony adapter that is made specifically for the lens on the Z7/S270 is a rectilinear lens. I have not yet tested the lens as it still is not available in my area but it should be quite safe to say there would be some residual distortions that may affect your work if you do a lot of shooting with architectural or geometric-shaped subjects. Whether this will be acceptable to you depends very much on your standards or your customers' requirements.
Historically, Sony have made good adapter lenses to fit their specific camcorder models. I own a few including ones that fit the Z1 and HC1. They are both excellent optically with moderate specs (not extremely wide or tele). Avoid extreme angle lenses from any makers if you can't put up with linear distortion and all the optical aberrations that could obviously be seen in your footage. But if you like the fisheye look, a few flaws may be tolerable and have to be.
Bring your camera to your trusted dealer that has it and try it on. See for yourself if it is OK for your work.
Wacharapong
Wacharapong Chiowanich is offline   Reply With Quote
Old September 18th, 2008, 12:26 AM   #6
Sorry guys,
But I find it pointless to purchase a camera with a removable lens option and then stick on an image degrading converter.
I'm not interested in wide converters. Tired of barrel distortion and fuzzy edges.
I've used the best wide angle converters in the business, and they are still sub-par to a dedicated wide-angle lens.
So...
Let me repeat: I'm not interested in wide converters.
I'm looking for info regarding the optional wide lens.
I thought they went on sale in June, where are they?
-BillP
Old September 18th, 2008, 01:59 AM   #7
The launch of the wide lens appears to have been delayed - I was told October (in the UK)
Mike Paterson is offline   Reply With Quote
Old September 18th, 2008, 09:57 AM   #8
Thanks Mike.
I'm holding off buying the Z7 to first see if I like the wide lens...
-BillP
Old September 29th, 2008, 12:23 PM   #9
Sponsor: Schneider Optics
Sorry guys,
So...
-BillP
I understand your feelings on this issue. The removeable lens is a major selling feature of the Z7U.
Having said that, I would encourage you to check out our new .75x converter for the Z7U that will be available for purchase in Mid-November. This lens truly is excellent and I have seen zero image degradation at the corners unlike some previous attachments that naturally caused a bit softer corners.
You are right that at the end of the day a removable lens is better but most cameras don't have this option. I would keep an open mind and check out both options. Our new lens might surprise you.
Ryan Avery
Schneider Optics
Ryan Avery is offline   Reply With Quote
Old October 1st, 2008, 12:54 PM   #10
...Oh boy not again...
That's fine if it's sharp edge to edge.
I don't want it.
It's the "look" of adapters that i want to avoid.
Read my first post again...and my 2nd...and my 3rd...
I want edge distortion...Rectilinear Distortion specifically.
I'm getting the new Canon 5D Mark II to use with my 16-35mm lens.
That's the look I'm going for.
-Bill
Old October 1st, 2008, 02:42 PM   #11
Hi Bill,
How about a nice screw-on wide angle adapter? They are really good I've heard.... :)
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
