FX1000 Compatibility at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old October 1st, 2008, 08:34 PM   #1
Any advice/cautions on intermixing Z7U footage with the new FX1000?
It looks to me like I should be able to do multicamera editing in FCP with the unmodified HDV footage from both these cameras BUT I'd hate to spend $3k and find out that I'm wrong.
Jon Goulden is offline   Reply With Quote
Old October 1st, 2008, 09:23 PM   #2
Just good old HDV capture as far as I'm aware. Shouldn't be a problem at all - I plan to buy the Z5 and mix with FX7 and Z7 footage. Easy peezy. Latest I've read is a November release date.
John Knight is offline   Reply With Quote
Old October 2nd, 2008, 12:04 AM   #3
So HDV is HDV? No issues at all? No concerns about frame size matching for multicamera editing?
Old October 2nd, 2008, 01:19 AM   #4
Correct. I've done shoots mixing Canon A1, Sony Z1, Z7 and FX7 all on same timeline... it's all 1440x1080. Not a problem.
Old October 7th, 2008, 10:26 PM   #5
Well just off hand... there is 720p30 HDV; 1080i60 HDV; 1080p30 HDV; 1080i50 HDV; 1080p25 HDV; 1080p24 HDV; 1080f30 HDV; 1080f24 HDV. Which ones am I missing?
But to get to your question, if you are using a few cameras that are all "XYZ" (X=480/720/1080, Y=i/p, Z=24,25,30,50,60) you shouldn't have any trouble editing them all together.
For multicam editing, you need to be more concerned with colors & time sync. Canon seems to be leading w/ the HDV multicamera sync work flow, but I think just about all Pro-line Sony cameras can sync timecode, & then half the battle is already won.
Zach Love is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
