Z7 telephoto zooms at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old November 26th, 2008, 01:42 PM   #1
Z7 telephoto zooms
Looking at the Z7 and wondering what zoom lens would be the best to attach to a Tapa lens mount. I need a lens for far off outdoor animal footage and also good in low light with no vignetting and also be able to get focus on images 2 feet way pulled wide. Also dont want to have to worry about using a bracket to hold the weight of the lens. Would you consider a Nikkor 100, 200, or 300. Thanks
John M. McCloskey is offline   Reply With Quote
Old November 27th, 2008, 11:18 AM   #2
I use the 70-300mm it offers a good med to long tele range.
Old November 29th, 2008, 04:23 PM   #3
Does anyone know what the mm of the stock lens is?
keithdbf
Keith Forman is offline   Reply With Quote
Old November 30th, 2008, 04:00 AM   #4
About 28mm-300mm its 4.4-52 so multiply by 7 to get the 35mm equivalent.
A 70-300mm nikon gives a range of 350-2100mm
Old November 30th, 2008, 08:56 AM   #5
2 of the Sigmas are excellent, the 120-300 f2.8 and the 100-300 f4. Just make sure that they are old enough that they still have an iris ring, as I believe the latest incarnations do not.
The Nion 50-300 is also nice, but no IFm and old lens now but still a good 'un.
Steve
Steve Phillipps is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
