NOISE REDUCTION in Sony HVR-Z7, what is this? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old May 6th, 2009, 03:37 AM   #1
Hello I saw in our new Sony HVR-Z7 a NOISE REDUCTION setting for audio. In the manual there is nothing about this... There only says "reduces noise from the microphone".
Does anyone know what this setting does and how and when you should use it?
Thank you in advance.
Steph Grueso is offline   Reply With Quote
Old May 6th, 2009, 11:03 AM   #2
I have tried it and it seems to cut rf type noise from the camera, certainly with it switches off I can hear more of the mechanisms in the camera bleeding onto the mic.
The wind setting is a different thing altogether and is a straight bass roll/high pass filter.
Old May 6th, 2009, 02:46 PM   #3
I presume it is meant to reduce the noise of the image stabiliser. When switched on, the image stabilisation system makes a clearly audible noise - a kind of humming - that is recorded in quiet circumstances.
Old May 7th, 2009, 01:12 AM   #4
So, then I presume you only have to use it when you use the mic mounted on the camera support. But there not seems to be a way to activate it in just one channel... It will it affect the other channel coming from the mixer. Would you leave it always on?
St.
Old May 7th, 2009, 01:36 AM   #5
St.
I would switch it off, because electronic noise reducing systems always mute some frequencies. Instead I would use a microphone with no omnidirectional characteristics somewhat further away from the camera. You could use the cold shoe on top of he cam to put a shotgun mic there.
Luc De Wandel is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
