CF Cards 64GB at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old May 15th, 2009, 02:12 AM   #1
CF Cards 64GB
Has anyone had a go at using a card larger than 32GB? I am hoping the firmware will let this camera format a 64GB CF card, as they are now a lot cheaper ($350 AUS) on ebay. This essentially makes the harddrive unit from sony non-viable as it is only 60GB. Why anyone would want to use a cumbersome harddrive in the field is beyond me, when the flash card is so much more robust and cheap.
Jamie Kehoe is offline   Reply With Quote
Old May 15th, 2009, 02:55 AM   #2
I use the 16gb cards as they are about the same length as a 63min tape and about as much data I am prepared to lose if it goes corrupt.
I suppose one 64gb card would be useful for a shoot which requires continuous recording but I would have to have the same length of tape in my S270 for safety back-up.
Old May 15th, 2009, 03:37 AM   #3
Originally Posted by Gary Nattrass View Post
I use the 32gb cards as they are about the same length as a 63min tape and about as much data I am prepared to lose if it goes corrupt.
Now you've got me confused, Gary; I use 16 gb cards and they get me 72 minutes in my Z7. I imagine 32 gb's should give you approximately the double, so the equivalent of two 63 minutes tapes, right? Or is the Z270 different in compression?
Old May 15th, 2009, 03:46 AM   #4
OOPS sorry my mistake i meant 16gb cards!
Old May 15th, 2009, 05:39 AM   #5
My mistake, too: Z270 doesn't exist. It should read S270, of course.
Luc De Wandel is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
