Progressive 30p vs Interlace 30p scan modes at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old January 23rd, 2010, 06:30 PM   #1
Just when I think I understand something, I come across a question that makes me realize i don't really understand it after all. Latest case in point - In the Z7 In/Out menu, under HDV Progressive, you can set the Rec Type to Progressive 30p, or to Interlace 30p scan mode. What is the Interlace 30p scan mode? Does that mean in records in 60i, but flags so it will play back 30 progressive from that? Is there a difference in quality? I've heard you need to be careful of recording in full Progressive mode (for footage given to someone else to edit) since some players won't play that. Thanks for any enlightenment.
- Tom Valens
Tom Valens is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
