Tape counter/time code not working at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old February 27th, 2010, 01:04 PM   #1
It's stuck to zero, I put a tape hit record but the tape counter is not moving on my Z7u.
am I missing something here? aaarg!!!
Rickey Brillantes is offline   Reply With Quote
Old February 27th, 2010, 03:01 PM   #2
problem solve!
Old July 31st, 2012, 10:08 AM   #3
Former Member #56430
Posts: n/a
Re: Tape counter/time code not working
Hi Rickey,
I have just started with this problem on the Z7 how did you fix it?
Dave.
Old July 31st, 2012, 12:23 PM   #4
Just a guess here...
Are there colons (:) showing between each pair of zeroes? If not, you have it set on UB instead of TC.
00 00 00 00 is UB
00:00:00:00 is TC
UB doesn't move because they are User Bits set by you.
Old August 6th, 2012, 09:04 AM   #5
Posts: n/a
Hi Adam,
Thanks for the information I will have a look and report back.
Dave.
Old October 11th, 2012, 02:53 AM   #6
Posts: n/a
Hi Guys,
I still can get this to work, I have pushed the button on the control panel on to of the camera and it cycles through have the colons and not having them.
Is there a menu setting I need to change?
Dave.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
