3 Quick Questions? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old March 13th, 2010, 09:09 PM   #1
3 Quick Questions?
OK. I have 3 questions.
1. Can you ONLY record to the CF adapter or do you have to record to tape AND that.
2. Can you review your shots, that you shot on the MRC1, in camera?
3. Is it possible to mix 2 mono channels. For example, Using an NTG-2 and a lavalier setup. Could you mix the two together in camera?
Thanks.
Michael Rees is offline   Reply With Quote
Old March 13th, 2010, 09:12 PM   #2
Wait, one more.
4. Does the CF recorder support progressive. And how many Mbps does it do?
Old March 14th, 2010, 12:53 AM   #3
Answer - you can record to both or just to tape or just to card
Answer - Yes you can just switch over to VTR mode
Answer - why mix in post
Rob
Robert Bec is offline   Reply With Quote
Old March 14th, 2010, 12:55 AM   #4
Originally Posted by Michael Rees View Post
Wait, one more.
Of course it does i think around 25mbps
Old April 9th, 2010, 08:32 AM   #5
Is there a way to record ONLY to CF using the cameras REC button? Or do you just have to use the Card Recorders REC button?
Matias Baridon is offline   Reply With Quote
Old April 10th, 2010, 02:07 AM   #6
Just change what you want to do in the settings and you can only record to card by pressing the record button
It's in the manual
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
