Week-long timelapse
Has anyone ever left a Z7 or S270 for a week filming timelapse? I need to do it in an industrial location and plan on shooting half a second every 10 minutes in DV, recording it to the CF card as well as tape. I'm going to power the camera from a mains adapter.
Any things I should know about before doing the timelapse? Should I check on the cameras from time to time? |
Have you considered using a DSLR?
If you set up an intervalometer, you can pretty much leave the camera to it's own devices. Plus a DSLR will let you use a longer shutterspeed which will help to even out any flickering due to changing ambient lights, and give it some motion blur to smooth things out so it doesn't look stuttery. It will actually be easier to work with stills in post because all you need to do is import all the images as a sequence - no putting clips together or adjusting speed. With all the extra resolution you also get the option of panning in post which can really add an extra dynamic to the time-lapse. |
Hi John, thanks for the suggestion, but I don't own a mains power supply for my Nikon and the battery won't last a week. I'm planning on using the video camera as I have all the necessary equipment already.
Vortex Media
I would suggest doing a test to see if you are going to like the results. Personally, I know a timelapse with 15-frame captures would be totally unacceptable to me. You're going to get a 1/2 second of motion . . . then a time jump . . . a 1/2 second of motion . . . then a time jump . . . etc. In order for a timelapse to look good, it really needs to be captured ONE frame at a time.
I would follow John's advice and use an SLR. Many of the newer Nikons have the interval function built right in, and power adapter doesn't cost much.
Vortex Media http://www.vortexmedia.com/ Sony FS7, F55, and XDCAM training videos, field guides, and other production tools |
#5 |
Thanks All,
It's in progress, with a Z7, an S270 and a Nikon D3 shooting from different angles. |
#6 |
Matt,
Get Doug Jensen's DVD on the Z7. In the DVD he shows you an example of why time lapse video work on the Z7 does not work. As a test I would run something for just a few minutes so that you don't burn up a lot of time only to discover you blew the whole week. |
