Focus Advice at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old February 1st, 2011, 10:26 AM   #1
Focus Advice
Hi Guys, being new to the Z7 I was wanting to ask about Focus. The two settings I kind of get and still getting there what switches on or off in Mode A or B.
My main question is which mode is better for an extreme close up A or B or using the Macro? I have had mixed results mostly the Focus not popping like it should, Could anyone offer any help on this.
Steven.
Steven Campbell is offline   Reply With Quote
Old February 5th, 2011, 05:58 PM   #2
Hi Steven, If I am getting you right. You are looking for the Best Settings for Close Ups, if that is the case two things to check.
1) Under CAMERA SET Change your AE WINDOW to TYPE 2. This will aid in your Focus area.
2) Zoom into your subject as far as you can, focus as best you can if you don't find what you are looking for come back towards wide slightly and find your Focus range, re frame if needed and shot is set....
I never use Macro as I have had some issues with my Z7 and Focus, I always thought it was myself it was the Limits of my Camera and an issue with my Lens.Maybe someone else will shed some light, in case I have provided the wrong answer?
Hope this helps.
James
Last edited by James Cairns; February 5th, 2011 at 06:26 PM. Reason: Spelling on AE Window.
James Cairns is offline   Reply With Quote
Old February 6th, 2011, 03:08 AM   #3
Hi James, Thanks for the advice. I have changed the AE Window setting to Type 2. I will use the method for Close Up's as stated, in fact I think I am going to ask a new question.....
Steven.
Old February 7th, 2011, 05:00 AM   #4
Hi ,
If your object (= face) is closer than ~80cm (er... have a look in the manual , MOD = Minimum Object Distance) or so, you either can move the camera more away (for focussing WITHOUT macro) or switch the z7 to Servo Mode + Macro On. Servo doesnt mean you MUST use autofocus.
I wouldnt use auto focus for closeups - the cam probably tries to focus to the background sometimes - so focussing manual is better.
In Servo + Macro you can go closer than the ~80cm, what can be a help.
I recently shot an interview straight in front of a person, Manual Focus Ring was hard left (80cm) and that was not close enough - the person is not sharp...
OR
Put the lens to 80cm (hard left), switch peaking on and JUST MOVE THAT DISTANCE away from your object that it gets in focus. Could work too without changing from Full Manual to Servo Focus.
Uli
Uli Mors is offline   Reply With Quote
Old March 3rd, 2011, 07:37 PM   #5
Re: Focus Advice
Hi there Thanks for the Tips. I will look into this, but the Methods mentioned before I have tried and I have also used some settings as a Guide from the excellent Two Disc DVD Mastering the HVR Z7U by Vortex Media.
With all this being so new to me and this year being so crap, I am taking baby steps and I apologise for that.
Steven
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
