Info on syncing two ea50s - Page 2 at DVinfo.net
Sony NEX-EA50 (all variants)
Old February 20th, 2014, 10:46 PM   #16
Re: Info on syncing two ea50s
Sounds good. I will have to give the plural eyes a try. Thank you.
Chris Brown is offline   Reply With Quote
Old February 21st, 2014, 08:29 AM   #17
I guess it's worth a try but free run for me is a bit painful ...audio/visual sync has never been an issue but I guess if you want absolute frame accurate sync then it will work for you. It just seems awfully complicated to have to use time code to sync unless, of course there is a specific reason
Chris
That's the whole point of timecode. Value for the Sony's with freerun is that with the remote lots of cameras can be reset to zero in free run mode then started and stopped at will. Edius for example will then sync all up on the timeline for multicam edit. NX5U, NX30U, EA50.s etc will do this together. Not quite as accurate as a full genlock but close.
Ron Evans
Old February 21st, 2014, 09:16 AM   #18
Thanks Ron
That might be quite useful at weddings so I can sync cutaways more easily. So to summarise you set both cameras to freerun and then point the remote at both and reset?? I must look at Sony Vegas to see what facility is there for timecode syncing as I don't use Edius.
Sometimes the celebrant steps to the side to do a reading so I need to use the second camera so that would maybe be easier than audio sync
Chris
Old February 21st, 2014, 10:14 AM   #19
Yes that is correct. Free run then use remote to reset. This will reset both cameras to zero timecode and then they will run free from zero.
Ron Evans
Ron Evans is offline   Reply
