Re: Sony VG900 - first image
SONY VG-900 ZEISS 15mm F2.8 ZF.2 ZEISS 85mm F1.4 ZF |
Had an extended hands on with the camera and some nice Alpha optics including some Zeiss models. My observations i random order:
• The sensor is not the same as the A99 sensor, as the autofocus sensor elements are different. • The AE3-adaptor for Alpha mount does not use a semireflective mirror, and is basically an upgraded AE1 • E-mount lenses will work - but not with out some vignetting - Beta firmware though, so this may change on the final camera. • E-mount lenses with power zoom will have active zoom and stepless aperture • Alpha mount lenses will only change aperture in full F-stops on the camera. • If APS-C lenses are used the camera will do an autocrop. APS-C crop can also be done manually, for lenses that the camera can not auto detect. Then you will get the 1,6 x cropfactor, • The XLR-adaptor can not be mounted on the camera, as there is not enough space between the two flash-shoes on the camera to mount the adaptor. You have to use a bracket of some kind. • The camera is very light. Meaning that larger optics will make the camera very front heavy. • The HDMI is *not* supposed to be clean. The A99 HDMI is clean – intentionally • The sound meters does not change format to a more traditional format, when the XLR-adaptor is connected on the camera, meaning that correct sound level is hard to judge. • Excellent picture quality - and possibility for extreme shallow DOF |
Do you know what the differences are in the sensor? |
No only that the embedded auto focus sensors are either missing or not active on the vg900. I believe that the cam has only one type of auto focus not a hybrid like the A99.
The VG900 does not have 1/3 stop light loss like the A99 with SLT mirror in the light path.
http://farm9.staticflickr.com/8343/8...c4f1073a_b.jpg |
| All times are GMT -6. The time now is 11:36 AM. |
