VG30 Hot shoe danger? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
Interchangeable lens AVCHD camcorders using E-Mount lenses.
Old June 4th, 2013, 12:14 PM   #1
Is there any danger of shorting out the hot shoe (FRONT) on the VG30 using the metal cold shoe plate on my camera light?
Ron Little is offline   Reply With Quote
Old June 5th, 2013, 09:15 PM   #2
Re: VG30 Hot shoe danger?
Good question. I have from time to time had metal on the hot shoe, but I try to avoid it. I'm not sure if the VG series auto detects flashes, but it seems to. Just went into the menu trying to access the hot shoe and it told me no flash was attached.
That - plus my own experience - leads me to believe it's probably safe. Just don't sue me if it isn't!
John Vincent is offline   Reply With Quote
Old June 6th, 2013, 08:05 AM   #3
Thanks John, I did not even think to look at the menu.
Old June 6th, 2013, 04:02 PM   #4
You got it - I only remembered it was there because I accidentally stumbled across it when in photo mode....
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
