Rokinon 35mm at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
Interchangeable lens AVCHD camcorders using E-Mount lenses.
Old November 4th, 2013, 02:41 PM   #1
Images: 4
Rokinon 35mm
I Finally got the Rokinon 35mm T1.5 Cine Lens for Sony E mount ,here are a few pics of the rig im building
There Can Be Only One
James Clarke is offline   Reply With Quote
Old November 4th, 2013, 05:49 PM   #2
Re: Rokinon 35mm
Cool! Great lens, I really like using it.
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old November 4th, 2013, 09:23 PM   #3
Images: 4
Re: Rokinon 35mm
Its fantastic , i will never go back to regular glass , primes all the way , i will be buying the 85mm next
Old November 25th, 2013, 08:02 AM   #4
Re: Rokinon 35mm
Nice rig. Could you let me know what you have attached as an audio recorder and how you attach it to the camera and tripod? Many thanks.
James Hollingsworth is offline   Reply With Quote
Old November 25th, 2013, 11:41 AM   #5
Images: 4
Re: Rokinon 35mm
No audio recorder as yet i still record in camera ,but im looking at the Tascam - DR-60D 4-Channel Linear PCM Recorder from B&H
Old November 25th, 2013, 01:47 PM   #6
Re: Rokinon 35mm
What sort of production will this be used on?
Old November 26th, 2013, 08:40 AM   #7
Images: 4
Re: Rokinon 35mm
I shoot mostly commercials and promos a local station , documentaries and features are what i live for
Old November 28th, 2013, 06:55 AM   #8
Re: Rokinon 35mm
Nice rig - James what magic arm do you use - I'm using a fairly cheap one and my monitor keeps working it's way loose.
Pete
Old November 28th, 2013, 08:56 AM   #9
Images: 4
Re: Rokinon 35mm
I bought it off ebay here is the link
11" Magic Arm for Lilliput 7" Monitor DSLR Camera Light | eBay
Old November 29th, 2013, 07:51 AM   #10
Re: Rokinon 35mm
I'm using a similar setup with similar equipment but with Zeiss primes coupled via the Metabones Speedbooster to improve the contrast and add that magical extra stop. The Tascam DR-40 4 track PCM recorder provides phantom power to the Rode NTG-3 and records 'ambient' via it's on-board stereo pair. I also run an audio feed from the DR-40, direct to the Vg20's aux input for a 'camera' copy of the mixed 4 track recording.
Craig Marshall is offline   Reply With Quote
Old December 6th, 2013, 08:19 AM   #11
Images: 4
Re: Rokinon 35mm
Hi I just upgraded my matte box with the Fotga DP3000 to match the rest of the rig here are a few more pics
Old December 6th, 2013, 04:48 PM   #12
Re: Rokinon 35mm
I like the 'swing out' design of their new matte box as it will speed up your lens changes. James, is the Rokinon 35mm a 'full frame' lens or APS-C/'Super35'?
PS: There's a company in China currently advertising on ebay who offer the 'cine mod' to new and second hand lenses from Canon and Zeiss. I've asked them for a quote to modify my collection of Zeiss FF lenses as re-fitting the rubber focus gear rings is a nuisance.
Old December 9th, 2013, 04:24 PM   #13
Re: Rokinon 35mm
the rokinon 35mm provides full frame coverage.
i am also looking int a rokinon duo-35mm/1.8 & 85mm/1.8.
keeping focus on an interview set seems reasonable.
i wonder how i would do in the field with the rokinons mated to my fs100.
any other users care to share their experiences with the rokinons?
any and all thoughts are appreciated.
be well.
rob
smalltalk productions/nyc
Rob Katz is offline   Reply With Quote
Old December 11th, 2013, 02:40 AM   #14
Re: Rokinon 35mm
Rob I use a 24mm Samyang with a focal reducer for an effective 26mm on a VG30. It's all run and gun in low light and I end up with about 70% in focus shots. It's still better overall than my NX70 that is easy to keep in focus but lacking in light in the same conditions.
For daytime shots I use a Rokinon 16mm with a glassless adapter as the focal reducer degrades the quality a small amount.
Matt Sharp is offline   Reply With Quote
Old December 14th, 2013, 05:27 PM   #15
Re: Rokinon 35mm
matt,
which focal reducer do you use?
Andrew Maclaurin is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
