FS100 and Atomos Ninja vs EX3 - Page 2 at DVinfo.net
Sony NXCAM NEX-FS100 CineAlta
Old January 9th, 2012, 12:47 PM   #16
Re: FS100 and Atomos Ninja vs EX3
Originally Posted by Simon Spear View Post
Walter and Sean
Thanks for your input. Apart from seeing the differences in low light and when doing lots of post work is there anything else that shows up when comparing the onboard AVCHD and the Ninja's ProRes?
Hallo Simon,
it depends on what you are shooting. I did some wide shots recently, the landscape on sunny day with some trees in the foreground and pine forest in the background, pines were moving slightly, and you can clearly see the artifacts on those pine trees when you watch AVCHD footage. With Ninja it is OK. No post work was done. I am watching my pictures on consumer Sony LCD 42´´ TV set in my editing room.
Walter Uhrik is offline   Reply With Quote
Old January 10th, 2012, 05:11 AM   #17
Originally Posted by Sean Vincent View Post
Hi Simon
In good lighting, there really isn't any difference visable to the eye. If you are just going to rely on getting the look you want in camera and not grade it at all, i don't see a problem with using the internal codec.
However, i'm a Final Cut user, and the AVCHD is a pain in the ass to work with i find... it's do-able for sure... but not ideal. Taking a Pro Res file directly from the Ninja to the timeline is pure bliss in comparison.
FCP will let you 'log and transfer' the AVCHD files, but only directly from the SDHC card they were captured on... if you've moved the files or are capturing from a back-up... it won't see them. Huge pain.
I use 2 small 120GB drives in the Ninja and that easily covers a full days shoot.
I only use the AVCHD when shooting 1080p slo-mo. This is worth the hassle of converting to Pro Res later as it's stunning... way better than the 720p that even the F3 shoots slo-mo in.
Sean I use a Nexto backup and always backup my SD cards to a second pocket drive. I have never had problems with the files I get from my current camera an HMC 150. My process is to create a dated folder and then copy the complete "Private" folder the camera creates into that folder. When I log and transfer I set the path to the "Private" folder within the dated folder I have created and it works like a champ.
Will this change with the files created in the FS100 I am about to buy? I will be using a Ninja as well but sometimes go only with the camera to keep the kit light.
Best
Brian
Montreal-Ottawa-Toronto
Brian Murphy is offline   Reply
