Great compact battery solution for the FS700 with power for the Alphatron. at DVinfo.net
Sony NXCAM NEX-FS700 CineAlta
Old November 30th, 2012, 08:15 AM   #1
Sponsor: Westside AV
I now have these batteries and cables in stock:
Swit Battery S-8972: Westside A V Studios WEB Store
They fit in the FS700 and uses the Sony charger. They also have a power tap that I make a cable for the Alphatron EVF (my favorite EVF). This makes the most compact and easy way to use an Alphatron on an FS700. I also make a cable that can use your existing D-tap cable from the Alphatron that plugs into the Swit, so you can use either D-tap battery or the Swit.
As you may know I also have a compact shoulder system and very adjustable rugged EVF mounting system in my WEBstore, that can accomodate AB or IDX batteries etc. I also have the new compact 15mm rail kit for the 700 in stock now.
Sony FS700 shoulder brace
Great compact battery solution for the FS700 with power for the Alphatron.-_mg_8856.jpg   Great compact battery solution for the FS700 with power for the Alphatron.-_mg_8859.jpg
Great compact battery solution for the FS700 with power for the Alphatron.-_mg_8864.jpg   Great compact battery solution for the FS700 with power for the Alphatron.-_mg_8871.jpg
Great compact battery solution for the FS700 with power for the Alphatron.-_mg_8880.jpg   Great compact battery solution for the FS700 with power for the Alphatron.-_mg_8886.jpg
Great compact battery solution for the FS700 with power for the Alphatron.-_mg_8889.jpg
