Any experiences with 60p AVCHD internal vs 60i external ProRes HQ recording? at DVinfo.net
Sony NXCAM NEX-FS700 CineAlta
Old February 5th, 2013, 02:11 PM   #1
Hi guys,
what are your experiences with a quality comparison (also in slow mo) of internal AVCHD 60p (or 50p in PAL countries) recording on FS700 vs external uncompressed or ProRes HQ 60i. 60p is better than 60i but uncompressed or ProRes HQ is better than AVCHD. I am asking because 60p external recording is not possible on Hyperdeck Shuttle 2 or Samurai (only 60i), it is possible only internally in AVCHD.
This question is not for owners of 60p external recoders:)
Petr Volgemut is offline   Reply With Quote
Old February 5th, 2013, 05:03 PM   #2
Re: Any experiences with 60p AVCHD internal vs 60i external ProRes HQ recording?
Originally Posted by Petr Volgemut View Post
Hi guys,
what are your experiences with a quality comparison (also in slow mo) of internal AVCHD 60p (or 50p in PAL countries) recording vs external uncompressed or ProRes HQ 60i. 60p is better than 60i but uncompressed or ProRes HQ is better than AVCHD. I am asking because 60p external recording is not possible on Hyperdeck Shuttle 2 or Samurai (only 60i), it is possible only internally in AVCHD.
I'm also interested in what experiences people have had and the quality comparison. For regular shooting it seems obvious to record external since you have to deliver 60i anyway. When shooting for slow motion the answer is less obvious as there is a trade off between bitrate and progressive.
In situations involving simple surfaces and movement where low bitrates work well, I would guess that internal recording in 60p would be better. In situations involving water and other complex moving textures, I would guess that external recording in 60i would be better. In this case, one needs to use high-quality deinterlacing to recover 60p before further processing.
Imperfections that are not noticeable during regular playback become much more obvious during slow motion playback. For example, the compression errors in the p and b frames from AVCHD source can end up looking quite strange, as if the trees and bushes are swimming underwater. This is especially true when using motion interpolation to further slow the video down. Another way of looking at it is this: If you record at 28mpbs and then view using 1/4 speed slow motion, the bitrate at the time of viewing is only 7mbps.
Eric Olson is offline   Reply With Quote
Old February 5th, 2013, 06:23 PM   #3
Sorry there is no motion, but there is plenty of detail, which also requires a high bitrate:
AVCHD 108060P, 28Mbps:
Recorded simultaneously on Ninja 2, Pro Res 422, 145 Mbps:
Mark Rosenzweig is offline   Reply
