Sony HDR-CX900 - Page 3 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
Pro quality results from Sony consumer grade equipment.
Old August 16th, 2014, 09:51 PM   #31
Re: Sony HDR-CX900
I noticed on the Sony Website that there is a firmware update for the CX900 that was dated Mid June. Has anyone updated their CX900, and is there an improvement in the auto focus as the update information suggests?
Any feedback would be appreciated.
Denny
Dennis Freeman is offline   Reply With Quote
Old August 17th, 2014, 05:55 AM   #32
Re: Sony HDR-CX900
HI Dennis,
I will check this out and if I am prior firmware I will update. We use this as a mounted cam on some shoots with decent success so far.
Paul Cronin
www.paulcroninstudios.com
Old August 17th, 2014, 06:31 AM   #33
Re: Sony HDR-CX900
Thanks Paul, I will anxiously await your results.
Denny
BTW, the update is located at http://esupport.sony.com/US/p/model-...d#/downloadTab
Last edited by Dennis Freeman; August 17th, 2014 at 06:41 AM. Reason: URL added for the location of the update
Old August 17th, 2014, 07:26 AM   #34
Re: Sony HDR-CX900
Dennis,
I did the update and reset the camera to my settings. Can I notice a difference just sitting at my desk? No
But it will get used again later this week and I will have a better idea once I upload those clips.
As I said we use this camera locked down on a suction cup spider, or in the hands of a producer for behind the scenes shots. I have also used it for personal use on my own adventures where is has worked well. Great little handycam
Paul Cronin
Old August 17th, 2014, 08:03 AM   #35
Re: Sony HDR-CX900
Hi Paul,
Thanks for the update. It will be interesting to see if the slow focus and the zoom speed updates were effective at all.
Denny
Old August 17th, 2014, 11:05 AM   #36
Re: Sony HDR-CX900
Couple more test and it does seem slightly better on focus.
Paul Cronin
Old August 17th, 2014, 06:23 PM   #37
Re: Sony HDR-CX900
Hi Paul,
Has the zoom speed been slowed down by the new firmware upgrade?
Denny
Old August 17th, 2014, 08:44 PM   #38
Austinite
Re: Sony HDR-CX900
Paul - Are you saying that when "producers" shoot they typically use a wicked awesome camcorder set to AUTO? Not trying to pull any punches here. Just curious.
Phil Goetz is offline   Reply With Quote
Old August 18th, 2014, 12:01 PM   #39
Re: Sony HDR-CX900
Dennis, don't want to keep you hanging but I am not near that camera till Thursday. At that point I will look at it further for you.
Phil,
Not really sure what your point is with this loaded question? The producers I work with are excellent and I mean excellent writers, and they see the big picture with skilled eyes and make the team better on every shoot I have been on. But they are not camera people. There are times when they want grab some shots and just want to hit record. That is when I set it to auto and let them use the camera.
Paul Cronin
Old August 25th, 2014, 07:36 AM   #40
Re: Sony HDR-CX900
Hi Paul,
Any update on this topic?
Denny
Old August 25th, 2014, 07:39 AM   #41
Re: Sony HDR-CX900
HI Denny,
We did use the camera again locked down as we normally do. So I do not have any info on zoom. But the focus seems to be a little quicker. Sorry that is all I have at this time.
Paul Cronin
Old August 25th, 2014, 05:12 PM   #42
Re: Sony HDR-CX900
Thanks Paul for the input.
Denny
Old September 10th, 2014, 11:00 AM   #43
Austinite
Re: Sony HDR-CX900
1080 from the CX900 should be better low light than 1080 from the AX100 because the AX100 has more pixels and they are smaller, right? Kind of like the PMW200 or 300 has better 1080 than the Z100 because the Z100 has more pixels and they are smaller, right?
Old September 10th, 2014, 11:45 AM   #44
Re: Sony HDR-CX900
"1080 from the CX900 should be better low light than 1080 from the AX100 because the AX100 has more pixels and they are smaller, right? Kind of like the PMW200 or 300 has better 1080 than the Z100 because the Z100 has more pixels and they are smaller, right? "
Wrong. The CX900 and the AX100 have exactly the same sensor and number of pixels. The CX900 is a crippled AX100 - it just doesn't have the capability of doing 4K. 1080 mode in the AX100 should be identical to 1080 from the CX900.
From the Sony site (Sony AX100):
"Pixel Gross : Approx.20.9M pixels
•Color Filter System : RGB primary color filters
•Imaging Sensor : 1" (13.2mm x 8.8mm) back-illuminated Exmor R® CMOS Sensor
•Processor : BIONZ® X image processor"
From the Sony site: (Sony CX900):
"•Pixel Gross : Approx.20.9M pixels
Are these mistaken?
Mark Rosenzweig is offline   Reply With Quote
Old September 11th, 2014, 08:58 AM   #45
Austinite
Re: Sony HDR-CX900
Wow Mark. Thanks so much for this. I totally missed the mark.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
