-   Sony TRV950 / PDX10 Companion (https://www.dvinfo.net/forum/sony-trv950-pdx10-companion/)
-   -   More Wide Angle Converter Questions (https://www.dvinfo.net/forum/sony-trv950-pdx10-companion/17282-more-wide-angle-converter-questions.html)
Michael Middleton November 18th, 2003 01:35 PM
I've gotta get a wide angle converter, but I don't want to spend over $150. It seems the Century Optics DS-HR65-37 is made specifically for the PDX-10, but it's a little out of my price range. I know Boyd is a fan of his Digital Optics converter, but am also considering the Kenco and the Tiffen. However, I can't figure out which of these, if any, have zoom through capabilities. For my application, zoom through is a must.
I like the price on the Kenco ($79 at B&H) and the Tiffen ($69 at B&H). Can anybody confirm if these are zoom through?
Michael
Harry Settle November 18th, 2003 03:15 PM
Don't skimp on the cost of glass. I recommend the Canon wd-58.
Boyd Ostroff November 18th, 2003 03:54 PM
That sounds like a real monster for a camera with a 37mm mount. Anyone actually use one of these on the PDX-10 or TRV-950? I'm sure it would be great on the VX-2000 or PD-150.
Jan Roovers November 18th, 2003 07:30 PM
Rainox HD-5000PRO wideangle 0.5x zoom thru
I am also looking for good zoom thru wide angle lens.
Can anybody tell me how good the Rainox HD-5000PRO is?
http://www.raynox.co.jp/english/vide...0pro/index.htm
It specifies 600 lines/mm. How do I have to read that?
Does it suit the 16:9 picture of the PDX10 without vignetting?
Frank Granovski November 18th, 2003 07:40 PM
I like the price on the Kenko ($79 at B&H) and the Tiffen ($69 at B&H). Can anybody confirm if these are zoom through?
The Tiffen is better than the Kenko in the 37mm thread size. There are also 2 Tiffen wides available. (See Tiffen's website.) The Raynox HD-5000PRO might be better that both the Kenko and Tiffen. I don't believe any of them are "zoom-through." I don't know how the PDX10's 16:9 mode/video quality will be effected.
Tony Caronia November 18th, 2003 08:33 PM
I have the Tiffen Mega WIde .56 that I use with my PDX10. It is not zoom thru. But it is very nice for $69.
Best,
Tony
Michael Middleton November 19th, 2003 08:47 AM
Thanks. The Raynox is an interesting option.
Does the Tiffen have front filter threads?
Chris Long November 19th, 2003 08:56 AM
..and the Raynox site shows a video clip, supposedly using the HD-5000PRO, while zooming. It looks like it might be good, but so hard to say from a small, compressed clip.
B and H mentions the resolution as "Achieving an amazing high definition of 500-lines resolution power at center..."
I guess I'm in the market too, since the holidays are approaching, so here's a stupid question: At what point (what fractional power factor, I guess is how I should say it) does one go from "wide angle" to a more "fisheye-like" effect? When does such distortion become REALLY obvious? (I actually like the look...)
Tony Caronia November 19th, 2003 01:07 PM
Yes the Tiffen MegaPlus 0.56X WA that I have has 72mm threads to accept filters.
It also fits the Cavision split ring 75mm OD for the 3 X 3 matte box.
Tony
Michael Middleton November 19th, 2003 01:32 PM
Thanks. I ordered the Tiffen this morning. The more I think about it, I can't really think of too many situations where I'd need the zoom through.
Now, about wireless lav's....
Tom Hardwick November 22nd, 2003 01:59 PM
A genuine fisheye lens implants a circular image onto the film Chris, and the lens 'sees' 180 degrees. Barrel distortion is 100%. A full frame fisheye (FFFE) doesn't vignette the image in this way, but you only see the full 180 degrees from diagonal to diagonal.
The term fisheye is abused in the same way as macro is, but it doesn't matter much. Any barrel distortion in a wide-angle lens is seen as a 'fisheye effect' and lens power has very little to do with it. Minolta make (for their 35mm cameras) a 16mm FFFE with huge amounts of barrel distortion, yet their 15mm rectilinear wide-angle is almost completely devoid of distortion.
tom.
Chris Long November 22nd, 2003 09:47 PM
Tom, thanks for the info. A related question:
What is the widest angle "normal-looking" power? Something around .5? If I get something in the .4 range, is it starting to veer into the odd effect category, and is not as naturalistic?
I realize this is a near impossible thing to talk about without images as examples, and I'm afraid I'm doing a poor job of it...all of it is so subjective, and the terms are abused, as you say.
Guilty!! ;^)
Tom Hardwick November 23rd, 2003 02:47 AM
Good question Chris, but look at it this way. Your PDX10 has a maximum wide-angle that should be prosecuted under the Trades Descriptio Act, for it's only wide in the fact that the lens sees more than at any other setting in the zoom range. In 35mm terms it equates to 50mm, and nobody ever called that a wide-angle.
If you pick up a Panasonic DVX100 you'll see that it's wide-angle is excellent - equating to 32.5mm right out of the box. Now say you attach a 0.5x w/a converter to each camera - the Sony now has a decent 25mm focal length and the Panasonic has a wild 16mm focal length (both converted to 35mm film terms as they use different sized chips which confuses the mathematics).
So yes, I'd say that you need at least a 0.5x on the Sony, but a milder (and less distorting) 0.7x will do on the Panasonic - and it'll STILL see wider than the PDX10.
All my tests show this: the more powerful the w/a converter, the greater the losses. Look at the Centyry fisheye - the loss there is to your bank account. But generally a 0.5x converter will be less sharp, will distort more, have more chromatic aberation and so on than a 0.7x. But as I say - in your case a 0.5x is about right and you'll have to live with the losses.
tom.
Chris Long November 23rd, 2003 08:58 AM
Great answer, Tom. Exactly what I was looking for.
Thanks!!
Jan Roovers November 23rd, 2003 11:07 AM
Rainox
I ordered friday the Rainox HD-5000pro.
I could get it in Leiden NL for € 89,- !!
I must give it a try. I let you know, how this lens performs when I have got and tried it: probably next week.
Chris Long November 23rd, 2003 11:18 AM
Excellent, Jan. I'm looking at purchasing it, too. I look forward to your comments about it!
89 Euros is a good price, I think--I see that B and H here in the US sells it for 139 US dollars, which I think is about 117 Euros.
Other dealers have it for less, but I'm not sure that I trust them...
Jan Roovers November 23rd, 2003 12:36 PM
The price was given by a known photoshop in Leiden. They know what they are alking about. They set for years now stunning prices. Leiden is a universitytown and they sell a lot to students and academics.
I think that such a lens can never go wrong.
They had to order it themself , so I know it is new in box and not used :-)
Chris Long December 10th, 2003 08:45 PM
Jan--
Sinter Klaus (or Black Peter?) is bringing me a Raynox HD-5000PRO this Christmas, though I don't think I am supposed to know that ;^)
It's hard to wait for it (2 more weeks!), and I was wondering: have you have gotten yours yet, and have you had a chance to evaluate it?
Jan Roovers December 11th, 2003 04:47 AM
Chris--
No not yet. They orderded the wrong one. So they had to do it over. I think I will phone them today if the proper lens has arrived now.
In this case I am my own "Sinter Klaus" and I am curious enough to evaluate the lens soon: before Christmas.
Boyd Ostroff December 11th, 2003 02:27 PM
Take a look at the horizon line in this frame grab. It should give you an idea of the barrel distortion with the .45x Titanium wide adaptor on the PDX-10.
Personally I like this effect and don't think it is all that odd. As Tom notes, the built-in lens is way too narrow and needs some help!
Shawn Mielke December 16th, 2003 09:05 PM
Yes please, Jan, tell us all about the Raynox, and don't hold back!
Chris Long December 16th, 2003 09:57 PM
I'll post a "review" of it, as well, when I get it in my hands (sometime on the morning of the 25th...) I ordered it from BugEyeDigital (they have it for $89US), and was pleased that it came very quickly and well-packed. Then it was spirited away to be giftwrapped.
I'm wondering, besides shooting things and checking focus throughout the zoom range, paying attention to how it shows detail, how the edges look, etc; exactly how I might do a really good review of it's qualities? Is there a good method I might follow? Some sort of template for checking it out? Never done it before in any way other than eyeballing it...
Jan Roovers December 17th, 2003 02:35 AM
shawn
My lens has not arived yet . I hope it will be delivered before Christmas. I will return with my "review" as soon i have tried it.
Tom Hardwick December 17th, 2003 03:31 AM
Chris - here's the test method I use. Set up your camera perpendicular to a brick wall and use a solid tripod. Side of your house is ideal - include door frames, wondows and any odds and ends that are lying about for details.
Shoot to Memory stick as this will show up the greatest detail when the frames are pulled into Photoshop for analysis. It also uses more of the chip area so any potential vignetting will be more obvious. Vary the shutter speed and shoot at maximum and minimum aperture (difficult to determine with the 950/PDX10).
Shoot at max wide-angle on the camera, then attach the wide converter and zoom to the same focal length (to give the same picture in the v/finder). Make notes. Compare these two frames in Photoshop. Look for colour and exposure differences. Look for distortion of straight lines, vignetting, flare and chromatic aberation. The brick wall test is excellent and shows faults very quickly indeed.
tom.
Chris Long December 17th, 2003 08:30 AM
Thanks, Tom. I'll do it, if and when Christmas gets here ;^)
Jan Roovers December 19th, 2003 04:13 PM
Got my Rainox HD-5000PRO
I got my Rainox this afternoon ! So I have not been able yet to test the lens in daylight, but my first impression is very satisfying:
1. The lens fits well in the wideanglehood from the PDx10.
2. The picture is sharp and full zoom thru.
3. Sharpening works as usual, automatic and manually!
4. In widescreen 16x9 there is practically no vignetting. I saw a very little darker border in one of the corners, but so small that it is very much out of the safe zone. It can not be seen on the LCD screen or in the viewfinder or on television.
5. In picturemode the vignetting is more visable in the corner.
The lens is delivered with a 37 to 37 (distance-)adapterring, but can be mounted on the PDX10 without it if no (UV-) filter is attached. I will try that tomorrow. I think that will help.
Overall the picture is very clear and very satisfying. I will test it tomorrow in daylight. The big advantage of the wideangle is also that it smoothes any unwanted movement of the cam, which occurs when no tripod is used. I could walk slowly with good results.
Jan Roovers December 20th, 2003 11:28 AM
Stills with and without Rainox HD-5000PRO
It was terribly raining and dark today. So I could not do much to test this wideangle convertor.
But I shot two stills to compare.
1. As said before: the PDX10 does not need the standard distance ring and when attached directly to the lens no vignetting can be seen.
2. The convertor is sharp in the middle but looses some sharpness in the borders. It is sharp within a circle with a diagonal of 50% of the diagonal in still mode. In Photoshop a softer contrast and a little less detail can be seen outside this innercircle.
I think it is the compromise of a convertor. What is your experience?
Nevertheless the picture looks well if not immediately compared and the problem will not be les evident in 4x3 videomode. In 16x9 mode however the left and right outsides are less sharp.
I have uploaded the pictures at:
Stills for comparison
As soon the weather will allow me I will make some more stills and frameshots.
Chris Long December 20th, 2003 12:01 PM
Thanks for the review(s), Jan, and for posting the still pictures. Very nice! I do see the blur in the corners you speak off--in the bicycle wheel at the left, for instance--though I wonder if the headlights of the car had any effect on the overall picture. Probably not, I guess.
Overall, very nice--I'm looking forward to getting my hands on mine. Thanks again!
Jan Roovers December 20th, 2003 04:16 PM
Chris:
I agree that the bike is not representative.
But you see a difference in
1. the houses at the left right above the bridge.
2. the poster on the workmans car
3. the cars at the right
4. the trees at the top.
The center of the picture is perfect.
It was 14.00 hr midday. You can see how dark and rainy it was.
I think the rain is affecting the picture also. Remember the lens is about two times bigger, 62 mm against 37 mm, so it will "catch" two times more raindrops in its field of view.
It was less apparent in tungstenlight inside my house.
One strong point is that this convertor has little or no color-diffraction/fringing.
I would be pleased to see comparison pictures from other wideangle convertors to. There must be a lot of wideangle convertors amongst members of the forum. Tom Hardwick's advise of testing pleases me.
So i will ask others to share some comparison pics with us from there wideangle convertors. It helps with a kind of forumreview.
David Korb December 20th, 2003 04:57 PM
Actually Jan..i really like the photo without the wa lens...am less impressed with the edges of your wide shot...was goinna shop for a w/a lens and now im not sure...does the tiffen and kenko also deliver soft edges ??
Jan Roovers December 21st, 2003 09:34 AM
I have updated my pics without rain:
pics without rain
Do you think this is the razorsharp as the Rainox-site promises?
To be honest I hoped for better, but may be I am demanding to much.
Chris Long December 21st, 2003 10:32 AM
Yes, it is a bit blurrier than I had hoped for. The image quality seems to fall off fairly quickly from the center out toward the edges. How does the image look in a close-up shot? Also, I'm thinking it won't be as noticeable in motion...
For others who have them (echoing David's question): Is this a common thing with adapters in this price range (the Kenko, Tiffen, etc)? Do they all exhibit a similar level of off-center blur?
Tom Hardwick December 21st, 2003 10:47 AM
The answer is a qualified 'yes', in the fact that all wide-angle converters degrade the image quality to a greater or lesser degree. The very best ones are so good that DV's resolving power doesn't show it up, and the less good ones make the losses obvious. They all add a bit of flare and they all soak a bit of light. Nearly all of them add to the distortion.
Converters are often focal length and aperture dependant too - which means they might be pretty sharp when zoomed in a bit and when used at f8. Moving away from these settings will introduce more losses.
I haven't tested the Raynox 0.5x, but the 0.66x I owned was very good indeed at max wide, and pretty bloomin soft at full tele.
tom.
Jan Roovers December 21st, 2003 10:48 AM
Yes Chris, I agree.
I hoped for a lens that i could leave on in most cases.
How are the Ceintury lenses? Are they any better.
Tom ,
what you see on my pics, is that normal for you?
Anybody has one?
Shawn Mielke December 21st, 2003 01:21 PM
Yes, Tom, I too am most curious about the Century adaptors.....
Tom Hardwick December 21st, 2003 03:33 PM
iIn my wide-angle group test for a British magazine my conclusions were this:
And the winner is…
The Century 0.65x. At just under £400 it’s the most expensive lens on test but it comes with proper lens caps that stay put, it has the best multi-coating and is the sharpest on test, regardless of the aperture used. Wide open it’s at its best in the centre but at smaller apertures the edges catch up. It doesn’t vignette the image at wide angle. There’s no filter thread but the breech lock bayonet is beautifully engineered, smooth as silk and makes the fitting and removal of the lens a quick and secure operation. Note that this only applies to the Sony VX2000, the Canon XM2 and the XL1s, the TRV900 and the DVCAM versions. There is a screw thread version available and a choice of three lens hoods.
It’s the heaviest lens on test at 325g, there’s just noticeable pincushion distortion at telephoto but overall it’s the winner. My only gripe is this. For a lens that isn’t very powerful it distorts straight lines too much. If I fit the 0.5x Cavision and zoom up to match the Century’s field of view I have a less distorting combination. And look at the Raynox – this lens has a lot less distortion for a quarter the price.
The Cavision 0.5x is a nice powerful converter though not without its faults. It has an 82mm filter thread and a 58mm attachment thread. It’s of three element, three group construction. It costs £144 complete with lens hood. The first two examples I looked at had specks of foreign matter between the elements and these were very obvious on footage shot with the lenses. The third lens was simply not as good as I expected it to be at the price so I asked for a forth sample to test. This lens was still disappointing although it gives remarkably little distortion for a powerful 0.5x, and for this I can forgive it some of its failings. It weighs in at 300g and the lens caps are useless, both of them falling off in warm weather. It comes in a leatherette draw-string case and has an 82mm filter thread. There’s a very good 4:3.5 aspect ratio hood that clamps to the outer diameter. Why not 4:3 Cavision?
At f2.4 the centre is as sharp as the Century, but the edges are way behind. By f11 the edges are better but diffraction has meant the snap has gone from the centre definition and colour fringing is most noticeable. Overall it’s better at f11 than at f2. There’s so much vignetting of the full DV frame that once cropped the 0.5x converter is more like a 0.6x. At full telephoto the performance is good at f5.6 and at this point the edges have sharpened up as well. www.cavision.com for more information.
The Raynox 0.66x is of three element, three group construction and sells for just under £100. It has a plastic box to keep it in, has a front lens cap that clips on securely and a rear cap that’s feeble, and weighs in at a lightweight 190g. The coating is nowhere near as good as on the Cavision and the Century, and hooding is recommended. It has a 72mm filter thread so this is not difficult to do. This Raynox is the only lens that you can use successfully as a converter for your 35mm still camera, where it handsomely outperforms all the rest. It’ll convert your 28mm f2.8 lens into an 18.5mm f2.8 lens with ease.
The instructions warn against using this lens past the half-way point on your zoom but I did some tests at full telephoto to check it out. Sure enough at full telephoto the image is decidedly soft and is covered with a veiling flare that is reminiscent of the effect given by the better soft focus screens. The effect is very aperture sensitive and at f4 it’s quite sharp in the middle of the frame with very soft edges. At f11 it’s soft all over and gives quite appealing portraiture shots.
At mid zoom it gives pincushion distortion but much better sharpness except right in the corners, and at wide it’s really a very good lens except that it vignettes the very corners of the frame. Overall it’s the best value for money here as its centre definition is indistinguishable from the VX2000 on its own.
tom.
Frank Granovski December 21st, 2003 03:41 PM
Tom, does this Century have 37mm threads?
I recall a local pro shop and customer here doing a test with a number of wides, including a Century, for the TRV950 and their conclusion was the Tiffen was the sharpest.
Tom Hardwick December 21st, 2003 03:49 PM
My tests were all carried out on, and are only applicable to, a VX2000 Frank, so you'd have to check the Century web-site for fittings available.
Frank Granovski December 21st, 2003 04:24 PM
So then the "best" wide for the VX2000's thread size is this Century, but you cannot assume another model made by Century will be just as good.
Boyd Ostroff December 21st, 2003 06:00 PM
Jan: Thanks for the e-mail that you sent, but I stupidly managed to delete it before responding!
Regarding the Titanium .45x lens, no I haven't had a chance to do any real testing of it, although it's something I've wanted to do for awhile. I'll try to take a few minutes during the coming week to shoot some example shots and put them online for all to see. Despite the holidays, things are rather busy at work here...
