CCD sizes - what is 1\4.7 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old September 23rd, 2004, 09:28 AM   #1
Looking at the info on the ccd of the TRV950. I understand that a bigger ccd is better so 1\3 is better than 1\4 ect.
But is 1\4.7 closer to 1\3 or 1\5.
Excuse my asking but math was never my strong point
Samuel Birkan is offline   Reply With Quote
Old September 23rd, 2004, 10:25 AM   #2
Hey, you got your backslash and forward slash confused... you must be a DOS user! ;-)
Seriously, 1/4.7" is sort of meaningless except as a basis for comparison. Like all fractions, as the number on the bottom gets larger, the measurement is smaller. So 1/4.7 is smaller than 1/4 but larger than 1/5. I agree it's confusing. The following article refers to digital still cameras, but may help explain a little: http://www.dpreview.com/news/0210/02...ensorsizes.asp
That table doesn't list some of the smaller ccd sizes. As a point of reference, the actual size (diagonal measurement) of the PDX-10/TRV-950 1/4.7" CCD's is 3.8 mm. A 1/4" CCD is 4mm and a 1/3" CCD is 6mm. So as you can see, a 1/3" CCD is significantly larger than what we have in our TRV-950's and PDX-10's...
Old September 28th, 2004, 10:47 AM   #3
Because the diagonal of the 35mm frame is 43mm, you can take that as its 'normal' lens. The diagonal of a 1/4" chip is 4.1mm and for a 1/3" chip is 5.5mm, so their 'standard lenses' should be those focal lengths. The 1/3" chip is actually 4.4mm x 3.3mm, so 1/3" doesn't really feature there much at all.
tom.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
