PDX10vs:PD 150 vs: VX2000 - Page 2 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old September 10th, 2003, 12:13 AM   #16
Ralph, you say:
I own both a VX2000 and a DVX100, and both cameras are significantly softer than any of the broadcast cameras I've used at work.
Are you surprised by this? My bet is the DVX100 and the VX2000 combined cost less than the lens for your broadcast kit. At the prosumer prices these Mini DV cams are being sold the lenses are 'just good enough'. Even so, it's not difficult for me to get an image on my big TV that looks significantly better than the signal I receive from the BBC studio via terrestial transmission, and all I'm doing is being careful with my VX2k.
tom.
Old September 10th, 2003, 12:46 AM   #17
Thanks Tom, for the image/lenses/pixels clarification. So much to learn.
Breakthrough In Grey Room
Shawn Mielke is offline   Reply With Quote
Old September 10th, 2003, 02:28 AM   #18
<<<-- Originally posted by Yik Kuen : For
Try this : Use your Digital Camera that shoot in native 640x480. Use another, shoot at 1600x1200 (2M) but resize it in PhotoShop to 640x480 and make a comparison. Although similar but they are different ! The latter usually looks better. -->>>
Digital Cameras are mostly single-CCD. Each pixel is either red, or green or blue (for RGB patern sensor). So their true red or blue resolution is much lower than stated VGA. Once you get higher resolution camera and downsample it to VGA level, the actual resolution improves because its color is much better.
However, this bears no resemblance to 3-CCD systems. Each color is full resolution and same as luminance. I believe you can see no diffeence in that case, unless there are aliasing artifacts, like Gints mentioned.
Vladimir Koifman is offline   Reply With Quote
Old September 10th, 2003, 10:28 AM   #19
Contributor
My two cents
The PDX10's CCD is oversampled in video mode. Thus, more pixels from the CCD block are being used for video than is strictly required. The result should be an image with less noise and perhaps wider dynamic range. This coupled with the camera's 14 bit processing yields a very high quality image. A note about the lens: even though it is not of the kind found in high end ENG setups, it would appear that Sony has learned a thing or two while working with Carl Zeiss. The lens does seem quite good. Certainly 'good enough' is not quite the right term in my opinion.
Ignacio Rodríguez in the third world. @micronauta on Twitter. Main hardware: brain, eyes, hands.
Ignacio Rodriguez is offline   Reply With Quote
Old September 11th, 2003, 11:00 PM   #20
Agree with Ignacio.
All mega pixel camcorder down-sample to NTSC/PAL resolution which is just about 400K. Through good algorithm and DSP, the images are better and have less artifacts.
And of coz, we must should not compare apples against oranges. Compare these ways :
1) Standard 1CCD vs Mega 1CCD.
2) Standard 3CCD vs Mega 3CCD.
Yik Kuen is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
