Routine Maintenance at DVinfo.net
Old November 27th, 2007, 10:14 AM   #1
Routine Maintenance
I have a Sony DSR 250 that is a little over two years old now. The camera is used a lot, but right now it seems to be working fine. The only problem I have had with it recently was some audio dropouts that went away after running a cleaning tape through it. However, this did have me worried that there might be some debris in the tape path.
My questions are now that I have some down time coming up with the holidays, would it be wise to send the camera into Sony for a professional cleaning and checkup? Does anyone else here do this? And if so what type of service do you request?
Jeff Wilson is offline   Reply With Quote
Old November 30th, 2007, 05:56 PM   #2
Most heavy use professional cameras get a cleaning, lubrication and alignment check done once per year.
Sony is very expensive as they charge a flat-rate. The local pro camcorder repair (not the corner tv repair) should be able to do this at a reasonable cost.
Mike Rehmus
Old December 3rd, 2007, 11:21 AM   #3
Thanks! I'll have to shop around.
