-   Sony VX2100 / PD170 / PDX10 Companion (https://www.dvinfo.net/forum/sony-vx2100-pd170-pdx10-companion/)
-   -   Sennheiser EW 100 (https://www.dvinfo.net/forum/sony-vx2100-pd170-pdx10-companion/16833-sennheiser-ew-100-a.html)
G. Lee Gordon November 8th, 2003 10:10 AM
Sennheiser EW 100
Hey guys... and gals, I just picked up a the Sennheiser kit and was wondering... How the heck do you mount the transmitter to your camera? Are you doing it on the battery? Please let me know.
Bryan Beasleigh November 8th, 2003 10:43 AM
First of all, you want to mount the receiver to your camera.
The easiest way is the Mini Rover or The Bracket 1
http://www.bhphotovideo.com/bnh/controller/home?A=search&Q=&b=1521&shs=&ci=3741&sortDrop=bs_asc&bl=&al=&pn=1&shs=&pn=1&ci=3741&Submit.x=17&Subm it.y=15
http://www.bhphotovideo.com/bnh/controller/home?ci=1&sb=ps&pn=1&sq=desc&InitialSearch=yes&O=SearchBar&A=search&Q=*&shs=mini+rover
The Mini rover will also hold a shotgun mic and provide you with a remarkably well balanced grip on the camera. With the rover you hold the camera against your chest with the elbows tucked in. It's amazing how it affects the stability.
Mike Rehmus November 8th, 2003 12:57 PM
I velcro the receiver to the back of the battery on my DSR-300 and just hang it on the hand-strap on the PD150. A little clumsy when I stick my hand in the strap but it works OK. That places it right at the best point for balance, right where my hand holds the camera. Anyplace else makes it a weight out on a lever and harder to hold.
Someday I'll make a bracket that clamps on the handle or the tripod socket and holds it in a velcro-closed clamp. Someday. Actually, maybe one of the brackets Brian mentions puts the receiver out to the right, outboard of the user's hand. That would balance the camera even better except when one does not have the camera up to eye level.
G. Lee Gordon November 9th, 2003 05:32 AM
Bryan,
I picked up something similar to that at my local camera store for 15 bucks. I ended up using the velcro strap that is inside the hand grip. Wasn't pretty , but worked fine for me.
I was wondering about attatching the receiver to the battery, but I use several batteries and different cameras. Thanks for the advice guys.
Bryan Beasleigh November 9th, 2003 01:06 PM
I've used cheaper L brackets but they never felt the same. Maybe I'm old and spoiled, but the Mini Rover makes a difference.
Jeff Natalie November 16th, 2003 06:19 AM
I built my own out of 2" aluminum painted black that extends out to the left of my PD150. It allows me to mount my shotgun and slide the reciever on it via the belt clip. Doubles as a handle when going handheld, works great. I just mounted it between my bogen footplate and the PD150 and bought a longer screw to go through the bogen plate and aluminum to the camera.
Dave Largent November 20th, 2003 11:28 AM
Regarding the MiniRover and Bracket 1: When they're attached to the camera, is tripod mounting possible.
Anthony Milic November 20th, 2003 09:34 PM
Check 'More Info' on the links that Bryan provided. It explains that there's no interruption to mounting cam to tripod.
Tom Hardwick November 22nd, 2003 02:09 PM
The Sennheiser comes with some 'industrial strength' self adhesive velcro, and I've stuck this to the VX's VAP OIS housing just rearwards of the lens hood's locking screw. This is a perfect place; smooth, flat and beautifully proportioned. The receiver clamps to the velcro and doesn't get in the way of any of the controls. Perfect.
tom.
Mark Goodsell November 23rd, 2003 10:05 AM
Not happy with what was out there on the market, I made my own. It's low profile and very sturdy. The receiver lies horisontally above the hot shoe, antenna facing forward. I can email a pic if anyone is interested.
Mark G
