VX1000 -- various topics at DVinfo.net
Old February 1st, 2002, 08:19 PM   #1
matteo151
Posts: n/a
Although the subject is not the VX 2000, I wanted to place this under the same thread, since it may be somewhat related. Basically, I am trying to decide which camera to rent for a one-day shoot I am doing next week and would welcome any feedback.
How does the VX 1000 (which is one of the possible cameras) compare to the Canon XL1 (which I am told is a PAL system). While PAL camera get better image quality (right?), how does the VX 1000 perform, in terms of image quality? Also, what about shutter speed and image quality in low-light conditions? Is this a no-contest situation, with the Canon coming out on top?
Any advice is welcomed.
Old February 2nd, 2002, 10:18 AM   #2
If your final output medium is US television, I'd avoid the PAL camera as conversion to NTSC can sometimes turn out to be costly, otherwise I'd go for the XL1.
The VX1000 and the XL1 were what I compared when shopping for my camera a few years ago and I went with the XL1. Better optics, even though Canon make the Sony's lens/OIS, better low light performance, interchangeable lenses, better zoom.
Adrian Douglas is offline   Reply With Quote
Old February 2nd, 2002, 06:49 PM   #3
matteo151
Posts: n/a
VX 1000/Canon XL1
Adrian,
Thanks for the brief opinion. I never thought about the conversion issue cost. For what my project entails, it's not worth the cost.
I will consider the Canon.
Old February 2nd, 2002, 07:33 PM   #4
The Canon is PAL isn't it. If it is, use the VX1000.
Old February 2nd, 2002, 09:38 PM   #5
matteo151
Posts: n/a
VX1000 or Canon
Oh, right. Thanks.
Old March 9th, 2002, 10:59 AM   #6
I am going to buy a camera and have heard that the Canon XLs1 is "better" than the Sony VX2000, but if you are saying that all XL1 are PAL (conversion issue) does that include the XL1s and if so, how can it be "better?" I hope I misunderstood the previous question and/or answer.
I borrowed a VX1000 to start my project but now want to buy a new camera to finish. I have been shooting cooking demonstrations in an indoor kitchen setting.
Please help. I am dangerously new to all of this stuff.
myusername is offline   Reply With Quote
Old March 9th, 2002, 10:12 PM   #7
The XL1 was the original release 3CCD Digital Video Camera back in 1998. It was available in both NTSC and PAL. The XL1s is V2.0, and upgraded model and was releases last year, it to is available in NTSC and PAL.
The reason some people in the US us PAL(25fps)is that it has a closer frame rate to film(24fps) and it has higher resolution than NTSC (625vs525).
If you live in a PAL country (UK, Europe, Aus, NZ, etc) then PAL is really the only way to go, but for US crew you have a choice.
Basically, and this is just my opnion, I'm sure people will disagree, If you live in the States, go with NTSC. There really isn't any noticable difference between the 2 and conversion from PAL to NTSC for local viewing can work out to be costly.
Hope the clears it up for you.
Old March 10th, 2002, 01:40 AM   #8
smartydraaws
Posts: n/a
i really recommend a book by Scott Billups "Digital Moviemaking"... if you don't have this book before you buy a camera i would get it... he explains the difference between cameras, formats, and he even explains compression pretty well... he is a little biased, but i think overall it is a good book... basically... he says... TRY em ALL BEFORE YOU BUY ONE...
for all it's worth... i have a vx-2000 and really like it... it has some audio issues, but i think the picture is better than the gl-1...
the more you research miniDV... the more you'll find out... every camera has it's own special issues... what you do... is you pick the camera that has it's own strong points where you want them...
good luck,
william
Old March 10th, 2002, 12:50 PM   #9
Thank you both sooooo much. You guys are great!!!!
Old May 31st, 2003, 12:42 PM   #10
How much does it cost for to fix the...
About how much would it cost to fix the viewfinder on a vx1000 because the picture has gone bad. It seems that it happens alot so would anyone know?
thanks!
Joel Landis is offline   Reply With Quote
Old May 31st, 2003, 11:03 PM   #11
I believe this is due to a bad ribbon cable connection. Perhaps someone here knows how much is involved for the repair. As far as I know it is an ailment which is not uncommon to this camcorder.
Old June 1st, 2003, 01:11 AM   #12
It is fairly expensive but if you are at all skilled with small tools, you can repair it yourself. The Price for the flex circuit is under $100 and you can find repair instructions on the Internet.
One of the techs at our local college just fixed 2 in this manner.
Mike Rehmus
Old June 1st, 2003, 03:16 AM   #13
See:http://videouniversity.com/wwwboard/vx1000/messages/175.html
Andre De Clercq is offline   Reply With Quote
Old June 1st, 2003, 06:44 AM   #14
Warden
The repair company I used to own charged just under $200 and we put a six month warranty on all parts and labor.
Jeff Donald
Carpe Diem
Old June 1st, 2003, 03:02 PM   #15
how much do you think it would be to send to sony? over 200? are there any other places where i might be able to send it?
