PD-170 media- DVcam and DV at DVinfo.net
Old March 27th, 2004, 01:20 PM   #1
Is it possible to shoot DV format using a DVcam tape in my PD-170? Reason being is I'm trying to stick to the same tape stock and some ceremony's (weddings) can be longer than 40 minutes. Thanks in advance.
Glen Elliott is offline   Reply With Quote
Old March 27th, 2004, 02:31 PM   #2
Contributor
Yes. It's a camera function, not a tape function. Go into the menu and switch over from DVCAM to DV. However, do not record a part of one tape in DVCAM and then the rest of it in DV mode--you'll have trouble capturing all of the footage. You'll get 60 min. record time off the 40 min. DVCAM tapes when shooting DV.
Old March 27th, 2004, 06:20 PM   #3
I thought that was true- just needed confirmation. Thanks.
Old April 2nd, 2004, 02:28 PM   #4
You can probably use the 80min dv tapes for recording events longer than 1hr in the dv rather than dvcam format.
Wes Mallard is offline   Reply With Quote
Old April 2nd, 2004, 04:45 PM   #5
I use 80 minute tapes frequently in both my 150's and have had excellant sucess with them. HOWEVER, I also will change a 60 minute during Communion (at a Catholic Full Mass ceremony).
The first menu is the shooting mode; just switch from DVCAM to DV and you'll be all set.
Don
Don Bloom is offline   Reply
