newbie question - can i change the heads on da pd150? at DVinfo.net
Old May 28th, 2009, 04:59 PM   #1
hi folks, i'm planing on buying another used pd150 on ebay, this cud be a dumb question but anyhow, can i still gets the heads changed or the cam serviced etc by Sony now, even though its been discontinued or has it basically got the same innards as the 170? I'm guessing it has. Therefore you can still get them serviced. Thanks
Donald Lazar is offline   Reply With Quote
Old May 28th, 2009, 05:02 PM   #2
shortanswer. Yes. Same as 170,250 so any qualified competent Sony repair shop should be able to handle it for you
Don
Old May 29th, 2009, 05:38 AM   #3
thanks again
