Agc at DVinfo.net
Old July 25th, 2004, 08:51 PM   #1
Agc
When outputting my DV from my NLE to my PD170 via firewire, I'd like to bypass the automatic gain control and set my volume levels manually. Is that possible? If so, how do I go about it?
Tony
Tony Zubrowski is offline   Reply With Quote
Old July 25th, 2004, 09:27 PM   #2
The only time the AGC circuit is in use (or not depending on your settings) is when you are actually recording with the camera. The camera settings have absolutely no effect when recording from firewire.
Mike Hanlon is offline   Reply With Quote
Old July 26th, 2004, 08:02 AM   #3
Is ther a way to reduce the volume then? It's recording the signal too hot. I want to reduce it about 6 db.
Tony
Old July 26th, 2004, 10:05 AM   #4
Why not do that in the NLE?
Billy Dalrymple is offline   Reply
