Unknown icon in PD-150 EVF at DVinfo.net
Old October 26th, 2004, 08:23 AM   #1
I have noticed an icon that looks like CP in the left side of the EVF screen. What is this for?
James Emory is offline   Reply With Quote
Old October 26th, 2004, 10:03 AM   #2
That would be your custom preset.
The button for it is located just behind the top carrying handle.
Cheers
Stephen Schleicher
www.stephenschleicher.com
Stephen Schleicher is offline   Reply With Quote
Old October 26th, 2004, 11:16 AM   #3
Great. Thanks Stephen. I have seen that menu for settings but why is that icon on? Can it be turned off?
Old October 26th, 2004, 02:17 PM   #4
You probably pushed the button by accident. If you push the button again, it should go away. Pushing the button will turn on your custom presets, and pushing it again will turn it off.
Cheers
Stephen Schleicher
Old October 26th, 2004, 02:58 PM   #5
Unless the PD-150 is different from my other Sony cameras, you will need to push the custom preset button, push in on the thumbwheel to highlight SET, then turn the wheel to select OFF and push in again to confirm. Finally, push the custom preset button again to make the menu go away.
