"Druthers" VX2100 PAL or NTSC ? ? ? ? at DVinfo.net
Old January 31st, 2005, 09:55 AM   #1
As I stated in an earlier thread, I am leaning towards an NTSC VX2100 because that is the region where I spend the most time. However, if there is a convincing reason to go with a PAL version, I will.
Really, PAL is daily life, and NTSC is for trips to Japan and the US one or two times a year.
If the PAL version will output NTSC, clearly I will go for the PAL too. But, I can't find that out!!!
thanks
Jack Wheeler is offline   Reply With Quote
Old January 31st, 2005, 12:04 PM   #2
You have to purchase one or the other as Sony doesn't make AFAIK, a model that works in both. I'm fairly certain it is just a different set of firmware that makes the difference but they don't publish that information.
I believe there have been lots of discussions about the choice issues and you can find them with a Search.
Mike Rehmus
Old February 3rd, 2005, 04:22 AM   #3
RED Code Chef
Also see this discussion:
http://www.dvinfo.net/conf/showthrea...threadid=38304
I would get the camera in the standard you do 75+% in, which
is probably PAL in your case
Rob Lohman, visuar@iname.com
Rob Lohman is offline   Reply
