sound problem with VX-2100?
Hi everybody
My set-up is : VX-2100 + Beachtek DX4 (stereo mode) + two mics. I just realized that the stereo separation is not 100%. It used to be a 100% or at least that’s what i remember! My left chan has a 5% of the right chan and vice versa. I tried an older mixer (studio 1 productions) but still the same. So this makes me think that it must be the camera , but i can't seem to find what. This is a real problem when I need two clean and independent channels. Any body has a similar problem? Thanks in advance Anthony |
Interesting, as I have the same setup and have never noticed the gentle dilution of one channel by another. So if you record with only one mic plugged into the Beachtek you actually hear it at a very low level on the other channel Anthony? I'd suspect signal breakthrough within the Beachtek due to improper wiring shields, though you could plug a mono mic direct into the VX to check out that as well.
tom. |
" So if you record with only one mic plugged into the Beachtek you actually hear it at a very low level on the other channel Anthony? "
Yes! And this happens with Beachtek and and older one I have(that is why it makes me think that is the VX-2100's problem). It is insane! |
Anthony,
When you are recording with only one mic plugged into the Beachtek, have you tried: 1. Make sure the Beachtek Stereo/Mono switch is set to STEREO. 2. Turn up the level on both Beachtek channels to max 3. On the VX2100 (assuming it's the same as a PD170): (a) Turn off AGC for both channels (b) Turn manual level control on for both channels (c) Turn the level of the channel with no mic completely down (d) Adjust the level of the channel with the mic for loudest sound to be at about -12db To double-check, switch the mic to the other channel and repeat the above. When you play back listen with each of these audio output options separately: 1. Output both CH1 and CH2 2. Output only CH1 3. Output only CH2 It's probably best to do this with a good set of headphones. |
#5 | |
The camera doesn't have split channel control, which is one reason that people buy Beachteks... and PD-170's! :-) |
#6 |
Yes Boyd, that's why I said "assuming it's the same as a PD170", because since I don't own a VX2100 I did not know for sure whether or not it had this capability.
#7 | |
Mike Rehmus Hey, I can see the carrot at the end of the tunnel! |
#8 |
Thank you all.
The problem occurs either with Beachtek and Studio 1 productions. Tha is why I feel there must be a problem with the camera. Thanks guys. |
