PD150 power supply for PD170? at DVinfo.net
Old October 19th, 2010, 07:48 AM   #1
Just wondering if it is safe to use the PD150 power brick for the PD170 and vice versa? I mistakingly did it once and it worked, but i was a bit concerned.
Mark Chafe is offline   Reply With Quote
Old October 19th, 2010, 08:35 AM   #2
Its the same power supply. You can use it without any worry.
Carlos Viteri - www.clvideo.com
Where Vision Meets Video
Carlos Viteri is offline   Reply With Quote
Old October 19th, 2010, 09:56 AM   #3
As long as the units have not been damaged, the power supplies are interchangeable. They are all Sony AC-L10 series adapters. Turn one over and look at the upper left corner on the back for the specs. They are all the same specs so you should not have any problems. I've had AC-L10 adapters for the old Sony D8 cams, a TRV 900 and several VX2000s, and all were interchangeable.
Jay West is offline   Reply
